Old 06-19-2012, 06:06 PM   #1
therex
therex is on a distinguished road
alternator
i know it may sound dumb but last night when i was driving, my car just shut off, had a dead battery, pulled the alternator off today, the ground is there but the plug isnt. no the plug is not just dangling somewhere, its seriously no where to be found! and im not sure what to do...
therex is offline   Reply With Quote
Old 06-19-2012, 06:30 PM   #2
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
http://wright-here.net/cars/rx7/manuals.html
Download the manual for your car. Trace down your wires, they may have broken and fell off?. Extend them if necessay and hook them back up. If the plug is nowhere to be found, once you find the wires, you can probably locate another plug at an auto parts store. It is a fairly common plug, or use female spade connectors as a temporary fix until you can locate the correct plug.
Old 06-19-2012, 09:21 PM   #3
What you got labeled as "Ground" is NOT a ground.
The entire alternator case is a ground.
What you got circled is actually the main power (+) output post.
Old 06-19-2012, 09:49 PM   #4
therex
whats the other one than?
Old 06-20-2012, 01:17 AM   #5
The other 2-wire plug is for feedback to the alternator (required) and signal wire to the warning cluster.
Old 06-20-2012, 01:22 AM   #6
therex
oh ok cool, found a cluster of wires just sitting around can anyone tell me which color wire is what
Old 06-20-2012, 04:53 AM   #7
Was this car running recently?
I believe the plug is going to be black (or was it white?), but looking at the "pins" in the back of the alternator, the configuration is going to to look like a "T".
You're looking on the "engine harness".
I don't think those wires / plug is going to be on that harness...?
It should be on the other harness snaking down the other side of the engine?
The car will not run right without the feedback wire plugged in.
Has the car have charging problems?
Old 06-20-2012, 07:04 AM   #8
88turboii
destroy, rebuild, repeat
88turboii's Avatar
the two wires that go to that connector at the back of alternator are blk/wht and wht/blk. a big thick blk wire goes to the charging post and connects to main fuse block. the blk/wht should see 12V with ignition on, wht/blk will turn on the charge warning light when it doesnt see 12V
Old 06-20-2012, 12:17 PM   #9
Raksj04
I have Ultra power in me.
Raksj04's Avatar
How long have you had the car? If an emission removel has been done that may explain the cut wires.
Old 06-20-2012, 05:39 PM   #10
therex
Yeah i drive it everyday and yeah i know, i dont have the plug, but im pretty sure i have the wires and yeah the battery keeps dying
Hmmm i looked at one of my buddies and the wires that went in were red/black and white/black
for a while now and idk havent looked
