Old 05-04-2008, 02:48 PM   #1
MidnightOwl
BAND. You got talent.
MidnightOwl's Avatar
MidnightOwl is on a distinguished road
Car won't stay running! W00t!
So I finished putting the S5 turbo into my S4 TII, and now I'm having a little bit of trouble. First of all, the engine is an 87 Turbo swapped into an 88 vert and has the full emissions removal. I put an S5 turbo on it a few weeks ago, and finished up the misc stuff on it today.
SO, I get in the car and try to start it but forgot that I robbed some fuses from under the dash. Replace those, and the car cranks and runs. Well after running for about 10-15 seconds, the engine dies. The car engine sounds fine while it's running, but after a few seconds it cuts off. So, the car cranks every time, but won't stay running for more than 10-15 seconds.
88 Turbo Vert - mostly stock, S5 turbo, full exhaust, Greddy Profec B Spec II, full emissions removal
90 240sux - daily driver of DOOM.
www.daviddrinkard.com
MidnightOwl is offline   Reply With Quote
Old 05-04-2008, 03:25 PM   #2
Ender
rotors excite me
Ender's Avatar
Which ECU and engine wiring harness are you using? Do you have the OMP in operation? Have you tried to grab any of the ECU error codes?
http://www.rotorwiki.com/index.php/86-88_Error_Codes
http://www.rotorwiki.com/index.php/89-91_Error_Codes
'87 TII
rTek 2.1 awaits a tune
Originally Posted by need RX7
360 gamertag: quick Tii
Old 05-04-2008, 05:40 PM   #3
Apac tii
Apac tii's Avatar
Apac tii is on a distinguished road
Did the car run before you put the s5 turbo in?
1988 Mazda RX-7 T2(list of mods here)
http://designengineeringworks.com/project_cars.php
2004 Saturn Ion Redline(dd)
1999 Mitsubishi Galant V6(the backup beater)
Apac tii is offline   Reply With Quote
Old 05-05-2008, 12:24 PM   #4
MidnightOwl
Yeah, the car ran fine before I installed the S5 turbo. The old turbo was bad, so I had to replace it.
I can't remember the ECU # off the top of my head, but it's the ECU and harness that came with the motor. I pulled the engine and everything out of a donor car and swapped it over. Like I said before, the car ran perfectly fine before swapping the turbos.
I haven't tried to pull codes, I had a wedding to go to last night and it cut short my time to work on the car.
I'm just seeing if anyone has a possible guess as to what could be the culprit. I can't really test for a vacuum leak because the car only runs for about 10 seconds. The car will idle fine during those 10 seconds, but just die.
Old 05-05-2008, 05:05 PM   #5
Ender
rotors excite me
Ender's Avatar
There's an intake pressurizer a guy sells online, you can pressurize your intake with the car off (INVALUABLE RESOURCE, GET ONE). I don't have a link off the top of my head, but I don't think it's too hard to find. They only cost ~$25.
'87 TII
Old 05-05-2008, 05:30 PM   #6
TehMonkay
Make sure the MAF is plugged in, sounds like its not plugged in, since the MAF is responsible for turning the fuel pump on after starting.
If not try jumpering the fuel pump check connector.
Old 05-05-2008, 08:11 PM   #7
MidnightOwl
Checked the MAF, it wasn't plugged in all the way...I haven't cranked it because I checked that while walking out the door to dinner. Gonna see if that fixed it tomorrow.
Old 05-05-2008, 08:15 PM   #8
TehMonkay
I will pretty much guarantee that will fix it as long as the connector wasnt damaged.
Old 05-05-2008, 08:16 PM   #9
TOMORROW????? The SUSPENSE WILL KEEP ME UP ALL NIGHT!!!!!!!!!!!!
Old 05-06-2008, 10:52 AM   #10
MidnightOwl
Yeah, it runs! I guess I knocked the plug loose putting it back together. OH WELL! It runs!!! The only problem is the gasket on the oil feed is leaky! Oh noes! Time to fix that! Guess I can drive it around the neighborhood now! W00T!!!!
