| Piston Engine Conversion Have you replaced your rotary with a V8 or any other type of piston engine? Tell us about it! |
#16 |
Rep Power: 14 ![]() |
Got the fuel line parts in a while back and started in on that. Got it mostly finished up during a couple hours here and there after work and what not. Started in the engine bay close to the brake booster and mounted the bulkhead fitting brackets via rivenuts.
![]() Here they are together ![]() Withe the -6AN bulkheads threaded in hand tight for now while I'm building everything. I'll add lock washers later to keep them stationary. ![]() Got this small section of the feed line finished up pretty quickly. On a side note everything above the bulkheads will be soft line to the fuel rails. ![]() Started messing with my fuel pump housing and stripped it down, measured stuff to see if what I wanted was possible, and it is but just barely ![]() ![]() I'm using a S4 housing since it's super easy to solder whatever gauge wire I like to the top of the pass throughs. ![]() Next i cut the factory feed and return tubes off the housing. ![]() Then drilled them out, to get a good starting point for what's next. ![]() -6AN fitting for the feed out of the in tank pump. and a -6AN bulkhead "T" for teh two return hoses. Hopefully they will be able to share the same return tube. If this ends up causing an issue then I'll add a second tube and replace the "T" with a straight bulkhead. PTFE washers to help keep fuel inside. I'll probably cut a countersink on the top side of the housing in each hole so I can put a O-ring under each washer, which should keep vapor from escaping. ![]() Just another angle. There is just enough room between the + terminal for the pump and the blue AN fitting for the feed. *wipes sweat from forehead ![]() Here's what the bottom looks like at this point. As you can see the feed has a tiny issue. There's not a completely flat surface for the washer to seat against. This is the reason I'll be adding the O-rings. ![]() A simple push-lok fitting and hose for the pump.
