#76 | ||
IT'S ALIVE!
Rep Power: 17 ![]() |
Progress is being made at the body shop once again. Teaser pics: ![]()
#77 |
IT'S ALIVE!
Getting there. The shop estimates about 2 more weeks and that's mostly due to waiting for a new rear window.
#78 |
IT'S ALIVE!
Posted a couple more pictures up on Facebook. Figured I should share them here as well. Not too much longer. Need to finish the rear window and waiting on some clips to install the sides.
#79 |
IT'S ALIVE!
Few more with the rear window complete and the TII sides installed. Last item is the OEM option TII front lip and it's done.
![]() ![]() ![]() ![]() My only gripe is the alignment of the side skirt and front fender on the passenger's side. I'm going to ask the shop get it as good as possible but I've come to realize perfection isn't attainable for what I'm willing to spend with aftermarket/used parts. |
#80 |
Its looking good. I like the orange.. any shots of the engine bay painted up? Did you make the rear hatch?
#81 | |
IT'S ALIVE!
Body work is done. I'm going to the shop today to wrap up everything and hopefully take the car home! |
#82 |
IT'S ALIVE!
TII lip installed and the car is back home. Now time for me to get to work!
#83 | |
Ooooh color is even better in natural light...
#84 |
IT'S ALIVE!
Did some stuff. The doors are back together and the headliner is in. I might need to dye the faded sun visors.
![]() ![]() I threw one of the wheels on to check fitment. It looks like it'll clear just fine but front camber is like -3.x degrees at this point. I spent a lot of time on Saturday hacking up the stock fender liners to work with the ~1 in. wider fenders. ![]() That's is how the car looked when I stopped last night. |
#85 |
IT'S ALIVE!
Most of the body is back together but before I start putting the wiring back in I need to figure out a heat shielding solution. I removed all the sound and heat insulation material from the car. There's only bedliner, metal, and carpet between the underside of the car and the interior space. Fortunately the exhaust manifold is ceramic coated but I want to add something to the inside of transmission tunnel and passenger's side at minimum to shield heat away from the interior of the car. Does anyone have any experience or products they could recommend?
#86 |
Did you already chuck the stock heat shielding sheet metal that runs under the trans tunnel/cat area? If not, I'd say just bolt those parts back in - it weighs very little and works well enough.
#87 |
Professional Stick Poker
The most effective heat shield is to place a sheet of aluminum between the exhaust and the body. Leaving an air gap on both sides and attaching the heat shield to the body not the exhaust. If you still have the factory heat shielding, it works better than any stick on alternative.
:edit: Pete beat me to it. I really must learn to type faster.
#88 | ||
IT'S ALIVE!
#89 | |
#90 |
IT'S ALIVE!
That's another option because I did keep all the heat shield mounting points. One thing I did before taking the car to the body shop earlier this year was bang in parts of the firewall and transmission tunnel. Hopefully that gives me a little more room to work with. Unfortunately with no engine in the car it's hard to line everything up.
