Rep Power: 21 ![]() |
I see VNT technology being good for this application
Rep Power: 10 ![]() ![]() |
yeah, I think its the difference in time.. I mean, I remember when PFCs were 1500+.. Now its only 700.
I'm beginning to like the idea of this and makes more sense. I guess i totally forgot about the whole maf system and been involved too much in tuning map based system. I'm very intrigued to learn more about this as this could work for older generation turbo systems.. I think its bit more complex compare to map, but I do see the advantage over it.
i think the problem is the turbos are getting out of their efficiency range when you start getting up there.
So are you saying that with MAF system can't hit XX Horsepower that MAP system will hit with the same turbo(s)??
#5 | |
MAF or MAP has nothing to do with it. You just are limited by the turbos themselves. The units that come on the FD are dinosaurs. |
can we get a mod to sticky this one, lots of good info coming out maybe useful in the future.
93 bb rx7 Destined to be the never ending project car or possible part source for the rotary rat rod 2008 40th Anniversary Edition RX-8 - bankruptcy owned me RE-Amemiya Super Dolphin Tail Exhaust-for sale AutoExe Front and Rear Strut Bars-for sale AutoExe Member Brace Set-for sale 2008 Honda CBR600RR - bankruptcy owned me Motivation axle/fork/barend/frame sliders ASV "unbreakable" shorty levers Tripage Integrated Tailight and Adj FE Proton Fushmounts Akrapovic Hex Carbon/TI Slip On Sato Rearsets |
I understand that different turbos have different efficiency and limitation..
Maybe I read it wrong.. But if your turbo makes 400hp top as its limitation on MAF based system and stock REW twin turbo (99s) will make close to 400 as its limitation on MAP.. I'm wondering if using MAF system on REW will produce similar HP... I guess maybe I got confused when you stated about temp and efficiency being the issue and wondering if thats one of the downfall of MAF based system to so called hitting maximum potential of turbo. I personally do not think FD units are junk/dinosaurs... Its very responsive and still one of the best sequential systems out there (mazda made FDs til 2002).. Many still prefers it vs. single, not just money but for its performance.. I mean, I still prefer it.. and really money wasn't an issue... I have a gigantic single at home that I could put on and make 500hp (T78BB) if I wanted to... but I know its not all about HP. BNRSupercar just recently put 99spec (280HP turbos from mazda) and at 14lbs of boost (MAP) on bone stock motor made 321RWHP. Conservative tuning and super responsive (I think full boost at 2300-2500RPM). If FD turbo system is dinosaurs and when compared to Modern Renesis motor and modern BB turbo, why is it that people not putting Renesis in FDs (like person like me with a spare renesis at home and 2x FD)?? is it because of money?? or is it because there is nothing to do with difference between MAF or MAP?? I think that's the bottomline I'm trying to get to.. Is MAF based system so much superior without any catch that even "dinosaur" turbos could be ran better??
DGRR 2013 - Year of 13B www.DealsGapRotaryRally.com http://www.facebook.com/Herblenny Last edited by Herblenny; 07-17-2008 at 08:52 AM. |
By the way Jeff, don't take me personally.. I do think MAF system definitely has its advantages... I just don't know its disadvantages...
I hope you understand I'm not trying to argue with you saying MAP is better than MAF.. I just don't know much about the MAF and knew better about MAP. I'm just trying to learn more by asking stupid questions..
#9 | |
#10 |
I am, by no measure whatsoever, insulted or offended.
I LOVE people that are inquisitive and I LOVE talking about this stuff. So, bear with me, because I get side tracked easily and have the memory of a flea, so it takes me a while to get things straight. |
#11 |
... yea, Jeff's our little flea, flea
#12 |
The Lancer Evo and WRX STI include both MAP and MAF sensors. I won't pretend that I know much about how their stock ECUs work, but they are two good examples of modern turbocharged engines. It would be much cheaper to use only one sensor as opposed to two, so that makes me think that there are enough advantages and disadvantages that the OEMs would want to use both.
It's pretty apparent that a MAP sensor alone doesn't tell you how much fuel to inject: for instance the MAP sensor will measure about 10psi on a bone-stock FD3S that makes about 250hp at the crank. I don't have a specific example in mind, but the same MAP sensor could measure 10 psi with an upgraded turbocharger, ported engine, and free-flowing intake and exhaust setups on a car that could be making over 300 hp at the wheels. The more powerful motor will require a lot more fuel, which is a good sign that it's flowing a lot more air. This is one example of how a MAF sensor could be very useful; a properly calibrated MAF sensor can accurately measure how much air is going into the engine (if properly calibrated) and simplify the tuning process (if you know how to use the data from your properly calibrated MAF sensor). Modern MAF sensors are not much more restrictive than an Intake Air Temperature sensor, you can install them in a bung that fits in any diameter of intake pipe (although you may need to re-calibrate the sensor voltage vs. airflow if you change the diameter of the pipe). Then again, there's more to tuning an engine than just making sure it runs at your desired air/fuel ratio. I don't know how a MAF sensor would help determine the "correct" ignition timing settings for making power. As with anything else, the most powerful ECU in the world won't do you much good if your tuner can't use it. You will need to find a tuner who is familiar with MAF-based systems or learn it yourself. Part of learning often involves making mistakes, and we all know how costly mistakes can be when turbocharged rotary engines are involved. By the way, cool site Mazdamaniac, and thanks for sharing a bit about the RX-8 ECU. Edit: meant to post this in the "MAF vs MAP tuning" thread in the ECU section. Nonetheless, thanks for sharing about the RX-8 turbo setups. Last edited by scotty305; 07-26-2008 at 03:11 PM. |
#13 |
Turboing a Rx8
Reading some of the posts in this tread, has made me think again... maybe it is worth turboing a rx8???
Good info guys
#14 |
I think so.
Its a matter of having clear goals and making correct choices. If you are building a dyno queen or a drag car, I'd say putting a turbo on the Renesis (as it sits) is a waste of time. If you are addicted to horsepower, the same holds true. However, if you want a streetable screamer that you can track respectably and still put your 1.5 kids in the back and go on a road trip while embarrassing STi and Cobra owners, than a turbo Renesis is more than up to the task. |
#15 | |
