#24 |
Modifying the Clockspring
First thing to do was to modify the stock clockspring to work with the new Efini wheel. The connector was too tall and in the wrong location for the Efini wheel to work, so I began by trimming about an inch off the top portion of the clockspring connector. After determining which pin was used for the horn, I soldered a longer wire to it to connect to the horn button then heat-shrinked and coated all exposed wires/pins then put the clockspring back together.
