| Garfinkle's Motor Works garfinklemw@gmail.com (TN) Custom products for 3rd Gen RX-7's |
Each new fitting has three o-rings to seal the part .The bracket is 3/8 steel ,the tube is a drilled through steel bar not thin wall tubing .The JIT fitting is brazed on ,not ferrule fit . The tube is brazed to the bracket as well .The fittings can be made with push on tubes for the stock rubber fuel lines . Chad may post picts of the fittings alone later .so you can see the o-ring set up .
