Old 01-19-2009, 10:53 AM   #2
classicauto
crash auto?fix auto
classicauto's Avatar
The RTV should seal fine if its applied properly and the surfaces aren't warped.
Hard to say what that issue is...
As far as rebuilding before strapping the turbo on - ABSOLUTELY. And unless your engine has been rebuilt fairly recently, you'll probably need more items then a soft seal kit as there will likely be 3 piece apex seals in it. Make sure to spec out all the hard parts....but a coolant o-ring, plus all dowel oring kits from mazdatrix are only a couple hundred dollars. But oil control rings/seals, all springs etc should be measured and replaced if necessary. But in my experience, unless its been fairly recently built or freshened - you'll be in for more then you think.
coolant seal failure, egr block off, rtv, vacuum leak
