Old 08-12-2009, 11:55 PM   #1
batmanfc
Rotarys Ruin Lives
batmanfc is on a distinguished road
'88 TII Oil Leak
I bought an '88 TII. It has a pretty bad oil leak on the back rotor housing gasket that goes between the back rotor housing and the rear iron. It's on the driver's side near the top. Its to the left of the oil filter. To fix this would I only need the gasket in between those two? It has great compression so I didn't really want to completely rebuild it or is there a way to temporarily fix it until I can save for a full rebuild? I was thinking something like jb welb or a really good high temp epoxy?
'88 Turbo II
'89 GXL
'07 Cobalt: DD
batmanfc is offline   Reply With Quote
Old 08-14-2009, 07:14 AM   #2
There is no gasket between the rotor housing and any of the irons.
If it's oil, it could either be...
1) o-rings on oil filter pedestal - relatively easy fix with relatively easy o-rings you get from the Mazda dealer
2) o-rings on the dowel pin - NOT easy to fix without taking the motor apart
Also check the oil pressure sensor within the same area...
Old 08-14-2009, 09:53 AM   #3
could be a cracked dowel land
Old 08-14-2009, 11:54 AM   #4
FC3S Murray
frustrated!
FC3S Murray's Avatar
if the o-rings were leakning for some time you would have a shit load of krud built up in that area. HOPE for that because if not, the rear dowel area is cracked. ** Was the FC modded and driven hard??
Same pig, new soul
Old 08-14-2009, 02:46 PM   #5
batmanfc
Rotarys Ruin Lives
No it hasn't been ran in a year. The iron is cracked unfortunatly.
'88 Turbo II
'89 GXL
'07 Cobalt: DD
Old 08-17-2009, 10:17 PM   #6
NoDOHC
NoDOHC's Avatar
Ouch. I guess you need one of three things:
A new rear Iron
A TIG
Some JB Weld.
(Sorted by quality of repair).
Old 08-20-2009, 11:26 PM   #7
batmanfc
Rotarys Ruin Lives
Thanks. Im just going to get a new iron so it won't result in problems later on.
'88 Turbo II
'89 GXL
'07 Cobalt: DD
