#6 | ||||
3 of them are emissions, while the (darker) green plug is for the twin scroll solenoid for the turbo. http://fc3spro.com/TECH/PROBLEMS/EM/solenoids.htm Quote:
I think yours is deleted and blocked off. Quote:
Any 1/4" (female?) spade connector can be crimped on. Also, BE CAREFUL to remove the outer wire braid shield on the wire itself before crimping the connector on. The outer braid is grounded on the other end. If you get this braid connected to the inner signal wire of the O2 sensor wire, you can blow electronics inside the stock ECU. Quote:
The BAC valve does a very good job allowing the engine to idle, especially on the street. Removing the BAC valve can cause idling headaches down the road. Hard to figure out what you're describing. Get some pics, and we can definitely help you figure out what it is... -Ted |
Bookmarks |
Thread Tools | |
Display Modes | |
