Old 09-11-2009, 11:47 AM   #7
jkstill
jkstill is on a distinguished road
My kit is the Coolingmist setup with trunk mount tank and Varicool controller.
The Varicool allows you to inject based on voltage or boost.
I took the simple route and am injecting based on boost pressure.
Calibration was done by using a MightyVac pump (also does pressure) and an external pressure gauge plumbed in, all connected to the varicool in place of the boost line.
I then set it to come on at low boost (6 lbs I think) and progress to 100% injection at 13lbs.
Then I pulled the output line off the pump, and connected up a line with another quick connect and a nozzle, turned it on, and used the MightyVac pump to run the boost up to 13 lbs. All worked great.
jkstill is offline   Reply With Quote
