Old 10-09-2009, 11:29 PM   #1
Redhawkjrt
Brake, Turn, Go! Repeat.
Redhawkjrt is on a distinguished road
NHTSA RX-8 clutch pedal failure investigation
From Autoblog.com:
"Mazda's RX-8 sportscar is under the watchful eye of NHTSA for a problem that could effect far fewer vehicles but the problem is equally serious. The safety administration has reportedly received 40 complaints of 2004-2008 models that have experienced clutch pedal bracket failure, and in 15 cases, the rotary-powered Mazda was moving and the drivers couldn't change gears normally as a result. Two of those drivers could have found themselves in a more dangerous situation, as the clutch pedal was reported to have become wedged under the brake pedal.
At this point, NHTSA is just beginning to investigate these issues, and if a recall results in either case, the government agency will assuredly issue notice."
It would be nice if there was a redesign - recall on these; on the other hand, it would definitely not be nice to have this problem at the wrong time, like, say, on the Dragon!!!!
Redhawkjrt is offline   Reply With Quote
Old 10-10-2009, 12:41 PM   #2
well no...if it does get jammed UNDER the brake won't that mean gears will not be engaged?
Old 10-11-2009, 03:16 PM   #3
The Partsgroup
The Partsgroup is on a distinguished road
We had one break at the top where it mounts to the backing plate. I ebded up bracing the area up that broke with small angles and rewelded it back up. It's a very crapy design in my opinion since the metal in that area is extremely thin. A recall would be nice for my street car but race cars or track cars can beef up that area to be safe!
The PartsGroup Inc.
Your Source For New & Used RX8 Parts
www.Partsgroup.com
256-309-0492
The Partsgroup is offline   Reply With Quote
