Old 10-10-2009, 10:58 PM   #12
NoDOHC
NoDOHC's Avatar
PP is not a bad option (although it will guzzle fuel). Really the PP and the turbo will have similar power bands and similar power levels. The fuel consumption will likely be comparable too. (The turbo is easier to do, the PP will run cooler and be lighter)
Wow! I should be more careful with my wording. Obviously, the turbo will not rev as high as the PP, and will make more torque down low (once the turbo spools). By power band, I was meaning that you will experience a low-rev power deficiency with both configurations.
I think that if you keep the PP downshifted, your throttle response would be better than with the turbo. You will probably have to shift less frequently with the turbo.
I think that a NA streetport would be fun on a hillclimb, mine makes pretty good torque from about 3,000 rpm to 9,000 rpm (good broad rpm range is better for racing as you are not always in the wrong gear).
I sure hope I get those rotors changed before the snow flies. (It is not currently looking good).
