Old 12-27-2011, 08:43 PM   #1
Pete_89T2
Pete_89T2's Avatar
Resurrecting an old thread... As I said before, Jeff's writeup inspired me to try this gauge mounting setup in my FC. 7 months later I finally had the time to do it! Previously I had my gauges in the empty DIN slot under the radio. Basically followed Jeff's general plan for flip-flopping them, by reusing the stock radio mount brackets and some hefty sheet metal I recycled from an old computer case to fabricate the panel. Started with some cardboard to make a template, and played with that till I was happy with the test fit. Then went to work recreating the template in metal. After some work with the jigsaw, hole saw and a bit of metal bending later, I got the gauge panel you see here.
Here's a picture of the panel, mounted with stock brackets, my JVC head unit & gauges test fit:
Lucky for me, the front threaded holes on my HU that lined up perfectly with holes already in the stock bracket, and they put the thing at just the right depth when test fit in the car, so I didn't have to resort to making slotted holes as Jeff did for the in & out adjustment. Just drilled a 2nd hole in each bracket (to get 2 screws per side for strength) that line up with another existing threaded hole in the head unit. Here's a pic that shows the screws:
And here's how it looks test fit in the car, without the console surround piece:
And now with the surround piece:
If the gauges look crooked, it's because I didn't bother to line them up perfectly and fully tighten the U-clamps on the back. I made the holes a wee bit oversize to provide a bit of adjustability. Now I just need to finish it, because I don't like the shiny metal look. Either going to paint it satin black to match the interior, or I might cover it with some black vinyl I have leftover from another project (DIY hatch cargo cover) that is a perfect match for my leather interior.
Old 01-04-2012, 08:13 PM   #2
JustJeff
JustJeff's Avatar
Attachment 11422
Attachment 11423
Attachment 11424
Attachment 11425
I like your's, great work.
I'm thinking of re-relocating my gauge. I'd loose my oil temp gauge and put my boost, water temp and oil pressure all on the a-pillar. I have one single pod and one double pod for the a-pillar. Reason being, I'm giving serious thought to building a carputer. I"ve been building computers for a long time and have enough spare parts to build a serviceable carputer. I've got a motherboard, CPU, RAM and spare hard drives. The only real expenses would be getting a 7" touch lcd monitor and building an enclosure.
The only other obstacle is wanting a solid state hard drive. My concern is that a traditional hard drive is going to fail from shock and vibration. I have Illuminas and Tein springs and I just don't see a non-SSD having much of a lifespan. I'd buy a small SSD and only keep OS and bare minimum software. All my entertainment would be on USB flash drives.
My idea is to put the enclosure in the trunk with a push button control in the glovebox for my power supply. I can also run a usb port from the glove box.
Well one other thing to consider is that I have a convertible and the LCD monitor is NOT going to like direct sunlight during the top-down warm weather. It may be so washed out from the glare that it will be barely useable. I may have to spring for one of the expensive LCD designed for outdoor use.
Originally Posted by yzf-r1
Old 01-05-2012, 07:39 PM   #3
Pete_89T2
Pete_89T2's Avatar
Thanks, since the last post I finished it off with a satin black paint that has a very fine sand-like texture to it. Matches my S5 center console texture & color well; will have to shoot a picture later to show it off. I tried covering the panel with the black fake leather as I mentioned, but that effort was a failure. The 3M spray adhesive I used didn't give a reliable enough "stick" along the narrow edges by the radio - vinyl kept curling up along the edges. So I had to strip it all off, then prep & paint.
Due to the motor-mouse belts, you can only get 1 gauge on the A-pillar of the S5 coupes; that's where I have my boost/vac gauge. Might be able to fit 2 gauges, but it would be tight. 'Vert owners catch a break here.
With proper shock/vibration isolation mounts, you shouldn't have any reliability issues with a regular hard drive in a car. 27+ years engineering experience with the DoD/Army has convinced me that even the most fragile of gadgets can be made to operate reliably in combat vehicles for a very long time with a well designed mount. Look in the boneyards for late-model luxury cars (MB/Lexus/Infinity, etc) that have built in hard-disk based nav & entertainment systems - you might get lucky and find shock mounts that can be re-purposed. Another source could be junked cop cars, as many now have shock/vibe mount plates attached to the dash/center console for laptops and all the other electronic crap cop cruisers carry these days.
USB cable length may become an issue here, presuming the motherboard/USB hub is in the trunk. USB spec calls out a max. cable length, something like 6 feet. Beyond that, and there's no guarantee that whatever you connect to it will work - some USB devices will, others won't.
Yup, that and polarized sunglasses will make just about any affordable monitor hard to read.
Old 01-06-2012, 12:42 AM   #4
JustJeff
JustJeff's Avatar
Yeah, I've thought about vibration dampening. I was thinking of finding some rubber stand offs from random electronics, but I like your idea of finding some OEM parts.
I've been thinking about the same thing with the USB cable length. Two options might be a powered USB hub or simply get a 32GB flash drive and keep it attached to the carputer and in the trunk. With something that large I wouldn't need to swap flash drives, I'd simply have to take it in to my desktop to update it.
Excellent point, I didn't even think about polarized sunglasses. Between the convertible and biking, nice sunglasses are a must. The cheapest I saw 7" touch LCD designed for outdoor use was $400. But I work for an IT company that does a lot of repair work. We have two techs making a killing repairing iPhones, smartphones, tablets and laptops. Maybe Fate will smile on me and I"ll find a broken touch LCD in need of repairs?
Old 12-28-2011, 01:42 AM   #5
I love making things like this. I did something similar but the FD doesn't have a whole lot of room to play with. I just remade a prior plastic piece though. I might have to do this with my TII, if I ever build it lol. This is awesome.
Old 01-05-2012, 01:36 PM   #6
That looks good! I'll definitely be keeping this in mind. Makes me want to get to work on mine haha.
Old 01-05-2012, 06:13 PM   #7
Raksj04
I have Ultra power in me.
Raksj04's Avatar
I would show you guys what I did but it isnt very good. All I have is a Dremel I really need a drill with a hole bit. I how ever have the radio on top and my car is a S4
Old 01-16-2012, 07:02 AM   #8
That's pretty badass man. Nice work.
Old 01-16-2012, 12:38 PM   #9
Raksj04
Raksj04's Avatar
Nice now only if some was able to make a group buy out of this.
Old 01-17-2012, 07:24 PM   #10
JustJeff
JustJeff's Avatar
Awesome work Pete!!
I definitely like that and had been trying to figure out how to angle mine. Can I see a picture from the side of your bracket. Looks like you have all 3 warning/Premium gauges. Only one of mine is the shallower warning gauge. I wouldn't be able to angle my Performance gauges because they are deeper and the far right one wouldn't have room because of the bracket. I suppose I could put the warning to the far right so that it can be angled.
I'm actually thinking of replacing my Prosports, so angling might have to wait till they are replaced...if I go with a different brand. Of my 3 gauges only my oil temp gauge is working. My water temp gauge and premium oil pressure gauge do not read from the senders. They illuminate fine but do not register any readings.
My water temp gauge was working at one time and now during opening ceremony it pegs at around 160 and never goes lower...even during opening ceremony. The water temp sender works fine. If I plug my oil temp gauge into the water temp sensor it reads just fine. The oil pressure gauge I bought new from a forum member. It was new when I got it. It illuminates fine, but never reads anything but zero. The oil pressure could be my bad on wiring, but I've double checked it and everything seems correct.
I may get some STRI or AEM rather than replace the Prosports with more Prosports.
Old 01-17-2012, 10:21 PM   #11
Pete_89T2
Pete_89T2's Avatar
Awesome work Pete!!
Thanks! Those are the only pictures I took before installing it back in the center console, so the additional side views may have to wait. These are the basic Prosport "Performance series", oil pressure, water & oil temp gauges that don't have the peak/hold warning features. If your gauges are significantly deeper, the bracket sides behind the panel will limit how much you can angle them. The good thing is that it doesn't take much of an angle to make them readable - presuming you don't sit too close to the wheel.
Sounds like your water temp gauge may have a fried stepper movement since you tested both the wiring & sender by substituting in the oil temp gauge. I'd check w/Prosport to see if they will cover it. The OP gauge sounds like either a wiring issue or a bad sender.
Old 01-18-2012, 08:37 AM   #12
JustJeff
JustJeff's Avatar
My temp gauges must be older version. They are much deeper than yours. My Premium/warning Prosport pressure gauge is short like yours. I doubt that Prosport will cover them because I bought them all from forum members. The temp gauges were used and the pressure gauge was new but not purchased from a vendor.
