| 2nd Gen RX-7 Parting Out Parting Out Mazda RX-7 You must have over 4 parts to list your items here. No new parts allowed. |
FC3S
Sent you a PM
Replying for 80leathersport, the connectors I need are the body side connectors that connect to the engine harness right above the ecu. One is bright yellow and the other is almost orange. about 6 inches of wire and the connector is all I need. They are almost impossible to get to, but they supply power to the injectors thru the engine harness. I also need the coil connectors, body side about 6 inches of wire before the connector.
Before you cut them off, I can send you pictures of the corresponding connector to make sure they are the right ones. Thanks, Charles |
