Old 11-15-2009, 12:57 PM   #29
Jeff20B
Jeff20B's Avatar
A 215mm setup. The disc is a smaller diameter for less inertia and higher burst strength. Grips less than a 225mm setup, but works fine for lower power levels. For example the 225mm setup described above boasts 268ft/lbs of torque holding capacity. The 215mm version holds 232ft/lbs. Unfortunately ACT stopped making them but some distributors still have them on the shelf. The disc is part number 3000205 and the HD pressure plate is MZ-016. The Xtreme version is MZ-016X. Not sure what the complete kit part number is.
