Vac hose size?
So replacing the injectors/injector seals, I broke more than a couple vac lines and went to get some replacement. I took along one of the old pieces and 5mm has a slightly smaller ID than the old pieces. i come home and test fit the hose before I cut it, expecting it to be snug. It's loose! Do I need 4mm hose, or will it seal well enough...[?] Mazdatrix lists 3.5mm and 6mm hose, but the pieces I removed look bigger than 3.5mm, and are definitely smaller than 6mm.
1990 Mazda RX-7 NA; Lucy, after the main antagonist from Elfin Lied. Eventual plans? Something cyberpunk and spicy. |
Simply Rotarded
I'm running the mazdatrix silicon hose and they fit correctly. I would recommend getting them or some that are the same id. They do look alot smaller than the stretched out oem rubber hose, but I believe that the silicon has alot more stretch than the rubber does.
LunchboxCritter - 91 NA to J-Spec TII - 88 FC Vert - 04 Rx8 Disclaimer: I am not a mechanic, and I did not sleep at a Holiday Inn. DO NOT TRY THIS AT HOME!!! Last edited by LunchboxCritter; 11-22-2010 at 04:11 PM. |
SG Imports closes @ 5:30 and I need to prep for class. I'll return the 5mm stuff tomorrow and grab some 3.5mm. I fantasize about the semi-pp 4-port I have planned...sigh.
Simply Rotarded
It'll be worth all of the trouble.
LunchboxCritter - 91 NA to J-Spec TII - 88 FC Vert - 04 Rx8 Disclaimer: I am not a mechanic, and I did not sleep at a Holiday Inn. DO NOT TRY THIS AT HOME!!! |
The semi-PP 13B or the silicone hoses? I have no damn doubt that silicone hoses will be worth the effort. But Lucy's hear needs a rebuild soon anyway, and I want her back together ASAP, so I won't wait for the nice stuff right now.
Good stuff at low prices
it's the 3.5mm for the small hoses. If you go to autozone they don't have metric hose usually, just fyi.
Yeah, they have 5/16" rubber hose, and that size fits a bit loose, so you need to zip tie each connection.
The 3.5mm silicone stuff works the best for cars IMO.
