| Fabrication Show off the parts that you've built from scratch or highly modified |
#11 |
Rep Power: 10 ![]() |
Soooooooooooo let's get back to the last 2 batches of pics I have before I need to do some more work and take some pics.....
So after quite of while of packing up the entire trailer as if I was heading off to the track, I took a length of pipe, suspended it between 2 cinderblocks and found the proper tongue weight, I marked that location and started pulling some measurements off the axle and transferring them to the trailer frame. Then I drilled holes from both the top and the bottom, and took some 3/4" OD .125" wall tubing and cut that to fit. The bolts for the trailer are .5" so they'll fit inside that tube just perfectly. The fear was, as I cranked down on the bolts to mount the axle, the 2" square tubing would deform. So I decided to support it with the round tube installed. Oh yeah, I had already run the wires for the lights at this point ![]() All 4 ready to go Very tight, and very almost ready to be welded. And finished welded in place. The snake survived and ended up being exactly where it needed to be, Closeup before I sanded everything down because the bracket needs to be flush mounted
