#10 |
rotaryevolution.net
Rep Power: 15 ![]() |
a MBC set at 0 doesn't vent anything, it actually allows all pressure to get to the wastegate, when raising boost with it it will vent slightly to lower the pressure opening the wastegate.
i would get a lower temp thermostat, check the water pump, blow any crap out of the radiator core and check for obstructions. if all else fails check to see if the cooling system is overpressurizing. edit: apparently it didn't go to the last page so nevermind.
http://rotaryevolution.net Last edited by Rotary Evolution; 04-02-2013 at 06:28 PM. |
