Old 06-05-2013, 06:53 PM   #7
infernosg
IT'S ALIVE!
infernosg's Avatar
Originally Posted by JL1RX7 View Post
I have used them in the past and got great pressure reading etc. But still had the same issues you're having. Went back to the old tried and true and got a few bubble out.
It shouldn't have picked up much water then. Just sucks that the fluid attracts water so no shelf life for it at all.
I'll give it a try. I'd think with the amount of pedal movement I'm getting there'd be a pretty big bubble somewhere.
It could be, are you saying that you don't put any fluid in the bleeder, and just use it to pressurize the fluid in the MC reservoir & system? You'll never manage to flush out all the air in the system with that small a volume of fluid.
Normally for a fluid flush & bleed, I'll dump a full quart of fresh brake fluid into the power bleeder tank, and it will take almost all of it to get to the point of zero bubbles and a solid pedal.
To avoid the mess at the end, do the following when you're satisfied the last brake has been fully bled:
1. Tilt bleeder tank such that the feeder tube at the bottom is no longer under fluid.
2. Crack open the bleeder screw on that last line, and let it slowly bleed out until the fluid level in the MC drops to the full line, then close the bleeder screw.
3. Carefully depressurize the bleeder tank by *slowly* loosening the pump piece from the tank. Make sure the tank is still tilted at this point so the feeder tube at the bottom is not immersed in fluid.
4. Now you can remove the adapter from the MC without the mess.
Yep, that's what I've been doing. I'll let the fluid in the reservoir get to the "LOW" mark and then fill it up again. I've certainly flushed more than a quart through the entire system by now. What pressure are you using with the Motive bleeder? Also, how much are you opening the bleeder screws? I've used anywhere from 5-20 psi and I've let the fluid come both rushing and slowly trickling out.
