| 2nd Gen RX-7 Engine Parts Only Engine Related parts ONLY! |
Reliable Source
Bought an engine for the rotors locally that had been previously rebuilt, however it spun a rotor bearing and i'm left with this stuff now...
It looks like it had a rotary aviation apex seal kit and wet seal kit installed. o-rings still good condition, I wouldn't reuse them (personal preference) but whoever buys an iron can have them all if they like. all parts are located in the metro-Detroit area, willing to trade for S5 NA rotors. All of the irons are in great shape, the center iron on one face has some hot spots but still looks usable, step wear of .003” at max S5 NA front iron - 70+ shipping ![]() S5 NA center iron - 70+ shipping ![]() ![]() ![]() ![]() ![]() S5 NA rear iron - 70+ shipping ![]() ![]() RA (rotary aviation) classics apex seals 100 shipped ![]() More parts for sale!!! S5 NA rotor housings - 65+ shipping each ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() They have some flaking, would be a good candidate for goopy or run as is, they include the turbo inserts already installed. S5 NA OMP with lines and injectors 55 shipped It appears to be in working order, no cracked lines and injectors are free of any debris. ![]() ![]() ACT lightweight steel flywheel for non turbo 50 plus shipping ![]() USDM FTP lenses, one has a missing stud, comes with hardware and everything you see – 40 shipped They can use a good polish but they are crack free and clean. ![]() ![]() S5 front and rear counterweight 80 shipped ![]() S5 NA intake manifold upper and lower with banzai block off plates, VDI included, 5/6th port sleeves are missing but rods are there. 100 shipped obo comes with what you see. ![]() ![]() S5 NA water pump assembly includes t-stat, housing, and water pump, great shape – 40+ shipping ![]() FC coils and CAS – 30 shipped for each, will lower price if you want multiple items. ![]() S5 GXL center caps good shape, some fade. 25 shipped. ![]() T2 aux e-fan unknown condition – 35 shipped ![]() For some reason when I bought this engine we could not find the other injector, what you see is what you get. Rail + injectors = 60 shipped. ![]() I also have an S4 e-shaft with hardware in great shape that came from a different engine (s4 T2) for 50 shipped. (pictures upon request) N326 NA ECU w/ bracket – 35 shipped My email is fidelity101@gmail.com PM or email me and I will get back to you with any questions. Last edited by Fidelity101; 06-01-2013 at 02:41 PM. |
Reliable Source
flywheel and apex seals sold!
Fan confirmed, it works. Each injector has 13.9 ohms resistance. 45 shipped for all 3 w rail. Both s5 na rotor housings for 120 shipped S5 omp w omp stuff 40 shipped. Willing to negotiate irons if someone is interested in all 3, possibly travel if near by ish |
Reliable Source
Injectors sold! S5 NA secondary fuel rail still avail. 10+ shipping
price update: If someone wants all 3 irons I will do $75 for all 3 plus shipping to lower 48 states. Shipping will be expensive forewarned I have to buy a plastic bin (about 10 dollars), then fill it will packaging bits (bubble wrap, cardboard and etc) and ship about a 100lb package through UPS with insurance, each iron is about 30-35 lbs a piece+ container. I shipped a complete differential assembly this way across the country and it worked out pretty well and came intact. |
Rotary since 1972
Do you have a BAV or neutral switch?
