#10 |
Professional Stick Poker
Had a question on it so I'll post this a little early.
I'm going stir crazy waiting for more pipe from RB, so I started figuring out the other big bug-a-boo with this swap. Cooling. Since the rotary requires far more cooling than the original piston engine, and frontal area is so limited, I had to plan out some rather strange stuff. The FC radiator is a single pass unit with 374 square inches of frontal area. The oil cooler carries about 30% of the engine cooling and is about 91.5 square inches of frontal area. The original MG radiator has only 140 square inches of frontal area and no oil cooler standard. Obviously we have a problem Houston. The tiny opening was going to need some rethinking to get a lot bigger radiator in there, not to mention what to do about an oil cooler. Here's a picture of the original opening after I had made some cuts to open it up a little. The Diet Coke box was supposed to only be background so you could see the opening better. Didn't work so well, but you get what you pay for. radiator opening 1 by Kevin Frank, on FlickrI'm going to open it up to the full width of the car. Removing the front stubs of the upper frame rails so I can fit the side tanks all the way up against the sides and maximize my radiator size with a 14" x 28" double pass radiator. I'm still down a little on frontal area from the FC radiator at only about 336 square inches, but I hope the extra efficiency of the double pass unit will make up the difference. Unfortunately it is going to have to be custom made so it's going to be expensive. The oil cooler I plan to use is an 11"x11" square stacked plate cooler that I will set underneath the radiator and between the frame rails. It is actually about 30 square inches larger in surface are than the original. However because I plan to mount it flat, (not much choice as there is just no room anywhere else), it will have less than great air flow. I plan to run a shallow scoop under the car to gather air for the oil cooler and run the fan shroud over the cooler along with the fan so that it draws air through both. A picture of the radiator opening, partially opened. radiator opening 2 by Kevin Frank, on FlickrI have to finish opening it up on the top pieces and cut down the frame rails.
