Old 09-24-2009, 02:05 PM   #8
dudemaaan
dudemaaan's Avatar
Originally Posted by Painter View Post
Any ideas on what to look for, I'm gettiing 12lbs of boost when it spools up around 250 rpms, as far as i can tell the second turbo may have issues, also
i beleive my idel is low around 600rpms.
Thanks,
Mark
You mean 12 lbs by 2500? That sounds pretty fast to me. Have you tried manually shifting it? Start in 1, and I think the automatic has some kind of button to make sure it stays in the gear you put it. If the turbo transition points are the same as a manual then you should see 10 psi pretty fast then a dip to 8psi around 4300 and then 10 psi again from 4500 all the way to redline.
