Old 11-11-2010, 03:06 AM   #1
Mateepay
Mateepay is on a distinguished road
Delorto 49 Ida?
So I have been slowly installing my delorto these past few days and I'm moderately confused on what to do with a few things...
I have the fuel return line? And nowhere to install it
The vacum advance for distributer
And i'm not sure what to do with the third cable running along with the choke and accelerator cable
Any info would be greatly appreciated
Mateepay is offline   Reply With Quote
Old 11-11-2010, 03:07 AM   #2
Mateepay
48ida
Old 11-11-2010, 07:27 AM   #3
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
Its a 48 DHLA (sidedraft).
If you don't have a return regulator then just cap the return for now. I run
the vent line into the middle iron nipple and have a PCV valve attached to the
oil filler nipple with vacuum on that. Don't run vacuum advance since I improved
my ignition.
Was that third cable for cruise control? Not sure what you want to do with
that.
Old 11-11-2010, 11:59 AM   #4
Mateepay
The only thing I can come up with is a hot start motor assist or a ac component
what's the esiest way to update the vaccume advance
Old 11-11-2010, 12:33 PM   #5
sen2two
KTEC
sen2two's Avatar
Make sure your mounting it the correct way. If you mount a side draft in a down draft position, it will not work. And vica versa...
what I have:
What I had:
Old 11-11-2010, 07:12 PM   #6
Mateepay
i mounted it the way i removed it off of my parts car im just a little confused about what is a must to keep for correct operation and which of the cluster of cables and lines i can chuunk
Old 11-12-2010, 10:16 AM   #7
t_g_farrell
Waffles - hmmm good
If you throw some pics up we might be able to help better.
Old 11-12-2010, 12:46 PM   #8
Mateepay
Old 11-12-2010, 12:48 PM   #9
Mateepay
Well that didn't work haven't been using the forum long enough to figure out how to import pics T_T
Old 11-12-2010, 03:04 PM   #10
sen2two
KTEC
sen2two's Avatar
Use photo bucket or something similar. It's usually easier that way than to load pics directly to the forum...
what I have:
What I had:
Old 11-12-2010, 07:29 PM   #11
Mateepay
DOES ANYONE ON HERE KNOW WHAT FILTER SIZE WILL FIT THIS RACING BEAT INTAKE COVER?? DELLORTO DHLA 48IDA IM HAVING NO LUCK T-T
Old 11-12-2010, 07:57 PM   #12
Mateepay
this is the piece idk what to do with do i need this to run the carb??
