Old 01-02-2012, 01:53 PM   #1
db86na
db86na's Avatar
db86na is on a distinguished road
another noob question about battery
so im working on my car last night and hooked up battery backwords for a split second, and then put it in the right way but now i have no power any were but all my fusses checked out not blown, but when i put battery on the charger it just says check battery, and also i can jump the car and it starts.. question is will hooking up a brand new battery wrong for a split second fry the battery
db86na is offline   Reply With Quote
Old 01-02-2012, 01:57 PM   #2
My5ABaby
My5ABaby's Avatar
By checked out, do you mean visually? If you didn't use a multimeter, try using the resistance (ohm) setting and see if there's continuity. I doubt there is.
Community Service Manual
RotorWiki
Old 01-02-2012, 02:01 PM   #3
db86na
db86na's Avatar
yes i have only visually checkd fusses i will check ohm
Old 01-02-2012, 02:06 PM   #4
Raksj04
I have Ultra power in me.
Raksj04's Avatar
He said It starts when he jumps it. When I installed it backwards before the battery was fine. Is it a Dual termnial battery? If it is try to hook up the battery to the other termnials.
Old 01-02-2012, 02:08 PM   #5
Raksj04
Raksj04's Avatar
When I did this before the 80A main fuse blew. It has 2 or 3 bolts holding it on, they are on the sides under the little flaps.
Old 01-02-2012, 06:51 PM   #6
Replace your alternator.... chances are you cooked that
Old 01-02-2012, 07:43 PM   #7
db86na
db86na's Avatar
its just a single top post cheapo from schwabs i took the battery and had it tested at schucks and it said it was toast. and also i do need to replace the alt its got some much belt dust inside it, why do these belts streach so fast its a brand new belt and the adjustment is maxed out and still loose.
Old 01-02-2012, 08:03 PM   #8
Mazdabater
FC3S
Your over tightening the belt.
Old 01-02-2012, 09:21 PM   #9
mattallac
mattallac's Avatar
mattallac is on a distinguished road
cheap belt? try a gates brand belt.
mattallac is offline   Reply With Quote
Old 01-02-2012, 10:19 PM   #10
My bet is underdrive pulley so you've actually got the wrong size belt
