Old 06-09-2010, 05:17 PM   #16
project86
Can't.Make.Up.My.Mind.
project86's Avatar
not speaking from experience here cause i obviously havent done anything yet... but it seems that making spacer for the sway bar should be a pretty straight forward affair. Oilpan on the other hand does not sound so easy.. but if your name is Brian... and youre half robot hahaa.....
'90 GTUs
'06 Toyota Highlander Hybrid
'10 Toyota Prius
Old 06-09-2010, 05:52 PM   #17
Revelc
20b Tinkerer
Revelc is on a distinguished road
Ah! You mean like this? http://www.rx7club.com/showthread.ph...ghlight=oilpan
Revelc is offline   Reply With Quote
Old 06-09-2010, 09:09 PM   #18
Originally Posted by Revelc View Post
DIY != low buck by any means, especially when you have more tools at your disposal than a dremel. Yes, the twins are already changed to non-sequential, and the TII drive train will be fine for the time being.
I do everything myself and I don't consider it low buck. There's DIY, and there's ghetto, and there's bought not built.
If you've got details on the spacer, by all means show me some pics or drawings and I'll fab one right up.
Think 1 1/4" AL bar stock drilled out and countersunk to bolt to the framerails, then two holes tapped ~1" farther forward to bolt the swaw bar mounts to. The LS1 guys use them, Granny's makes them I think.
EDIT: All the new oil pan setups I've seen are for dry sumps, which is a far more expensive ordeal than a new sway bar. Again if you've got drawings/pics let me know and I'll be more than happy to make one. The purpose of this thread was to find out what plans were in the public arena before I went reinventing things.
Build your own pan from AL, I thought that was clear. I never said anything about dry-sump
do me a favor please and img blah blah blah /img tag it for me.... I'm banned again
Old 06-09-2010, 09:28 PM   #19
Revelc
20b Tinkerer
Heh
stock
At the end of that thread patman gives his blessing for people to copy it, so I've sent him a PM.
On the topic of the oil pan, I read that as 1 1/4" because I'm retarded. Either way moving the sway bar forward is a much better solution for the time being.
That's what was in my head when you said new oil pan.
Old 06-17-2010, 01:59 AM   #20
jamespond24
jamespond24 is on a distinguished road
Ok does anybody have pictures where they mount their oil cooler and want waterpump housing do they use?
jamespond24 is offline   Reply With Quote
Old 09-18-2010, 02:48 PM   #21
hIGGI
hIGGI is on a distinguished road
moving swaybar to the front is not option for drift car ;(
i am already hitting swaybar at full lock and with swaybar more to the front it will be worse..
hIGGI is offline   Reply With Quote
Old 09-18-2010, 05:12 PM   #22
justin lilley
20B
justin lilley's Avatar
justin lilley is on a distinguished road
Solid mounts ..
This is what worked on my FB
[IMG][/IMG]
[IMG][/IMG]
justin lilley is offline   Reply With Quote
Old 10-09-2010, 08:32 AM   #23
hIGGI
For my 20B FC i installed z32 swaybar last week, took me half the day to get it mounted, its 27mm, clears stock oil pan no problem and so far it works no problem (did only 800km street driving - breaking engine in)
And its no worse than Racing Beat swaybar i had before, when it comes to be in the way of wheels at full lock (spacers for tie rods installed, in steering rack, more turn for drift competition....)
Old 10-09-2010, 12:09 PM   #24
hIGGI needs to start his own 20B thread...
