RX-7 3rd Gen Specific (1993-2002) RX-7 1993-2002 Discussion including performance modifications and Technical Support Sections. |
Victory Is Mine
What underpan are you running with FMIC
I am just seeing what people are running for a underpan with FMIC. I have a Blitz FMIC and I tried to test fit the stock underpan last night, well look like it wont fit due to the radiator being too low. Any suggestions?
l8r
![]() www.dealsgaprotaryrally.com 1994 Rx7 White 2001 RZ GT35R'd 1972 Rx2 Orange Coupe 5spd 2006 STi 1986 Buick GN |
you are supposed to cut and trim the stock undertray for it to fit.
Rep Power: 10 ![]() ![]() |
try 99 under tray
Victory Is Mine
Well i have both the 94 and the 99+ underpan so if I cut one up im gonna start with the 94 pan since im not doing the 99 bumper till later this month more than likely. I figured this is pretty much what Id have to do just cut the stock one up a bit.
l8r
too low? you sure you got everything mounted correctly?
goodfella is running that same IC and i believe he is running the stock undertray. |
Victory Is Mine
Ill look at it again but its pretty tight with the new brackets on the radiator.
The Judge
You have to remove the piece rivited to the main body.
Bookmarks |
Thread Tools | |
Display Modes | |
