Old 04-26-2008, 12:01 PM   #1
PercentSevenC
Custom User Title
PercentSevenC's Avatar
GSL-SE fuel pump flow?
Anyone know what the GSL-SE fuel pump's flow rating is? To cut costs I was thinking of using one on my blow-through project for the time being.
Old 04-28-2008, 02:15 PM   #2
Jeff20B
Jeff20B's Avatar
Don't they flow at least as much as a walbro 255lph? C'mon guys. Anyone know?
Old 04-28-2008, 04:09 PM   #3
I dont think they'd match the 255lph. I'd imagine they are closer to the S4 NA 13B pump which is less than 255 - I used to have a chart somewhere...
Either way, it wont do for much more than 6psi I'd imagine...
Old 04-28-2008, 10:03 PM   #4
BadAzz84
BadAzz84 is on a distinguished road
gsl-se pump will work fine for a blow through turbo they put out like a max of 40psi
BadAzz84 is offline   Reply With Quote
Old 04-28-2008, 10:59 PM   #5
PercentSevenC
Custom User Title
It's not the pressure I'm concerned about; I know that will be plenty. I'm concerned about how much fuel it will flow at lower pressures, like around 15 PSI. I think it needs to be like 30-35 GPH at that pressure.
Old 04-30-2008, 03:59 PM   #6
Jeff20B
Jeff20B's Avatar
Does anyone know? You might want to ask on the other forum. It's important because I found a GSL-SE pump for you. I'm working out price right now.
Old 04-30-2008, 08:09 PM   #7
BadAzz84
Well before i went turbo on my 12a i was told that that pump would be great for blow through. i couldn't find one so i got a msd 2225 works great.
Old 04-30-2008, 09:40 PM   #8
Jeff20B
Jeff20B's Avatar
Thanks for the info.
Old 04-30-2008, 11:47 PM   #9
PercentSevenC
Custom User Title
Yeah, I was thinking about using a Summit-rebranded MSD 2225 as well. I think the GSL-SE pump should probably be enough for now, too, so it'll come down to what I can find when the time comes.
Old 05-01-2008, 09:48 AM   #10
BadAzz84
Should work either way guess you could use a wolboro.
Old 05-01-2008, 12:30 PM   #11
Jeff20B
Jeff20B's Avatar
You could use the GSL-SE pump while you're running 5 psi. You're looking for cheap solutions and this is it.
Old 05-25-2008, 09:05 PM   #12
nobodymv
nobodymv's Avatar
nobodymv is on a distinguished road
After research, I FINALLY found the answer to the original question:
Specifications:
Design: Intank
Flow: 160LPH
Minimum Voltage: 12V
Max Operating Pressure: 95 PSI
Part Number: SPPG-392
It is the same part for:
1986-1989 Acura Integra
1990-1992 Daihatsu Rocky
1984-1985 Mazda RX-7
I hope this helps you !
nobodymv is offline   Reply With Quote
Old 05-25-2008, 11:14 PM   #13
Jeff20B
Jeff20B's Avatar
The GSL-SE pump is external. Your list states Intank.
Old 10-13-2008, 10:04 PM   #14
nobodymv
nobodymv's Avatar
Go to your local Dodge dealer and have a look at the fuel pump that they use for the viper. It’s a Bosche pump that is identical to the HKS upgrade pump. One of my guys picked one up and put it in his car and the pump only cost about $130. Check it out.
Old 10-13-2008, 10:53 PM   #15
PercentSevenC
Custom User Title
I ended up picking up an MSD pump for like $40. But, good to know. Is it an external pump?
