Old 09-14-2008, 09:39 PM   #16
Originally Posted by maui_boi View Post
k i checked all of it and they work and i disconnected the TPS and it idled good just still getting that bad runing at and after 4000rpm
You checked the spray pattern on the injectors? You checked to make sure they're firing off correctly?
It honestly sounds like your secondaries are clogged. Pull the rail and injectors, use mechanics wire and read the fsm on how to test the spray pattern on the secondaries.
Old 09-14-2008, 11:39 PM   #17
witchhunter.com
enough said.
Old 09-15-2008, 01:03 AM   #18
maui_boi
FC Rotary Power
maui_boi is on a distinguished road
well i only cleaned em for now im gonna test it when i have the time i only had time to clean the injectors but i will keep u guys posted cause this car is giving me problems lol
maui_boi is offline   Reply With Quote
Old 09-15-2008, 09:17 AM   #19
how did you clean them? It requires special tools.
Old 09-15-2008, 10:16 AM   #20
My thoughts exactly.
Usually, and I mean usually; cleaning injectors require ultra sonic bathing, back flowing, and taking measurements throughout the process to ensure that they are flowing properly.
Flow benching the injectors to +/- some percentage and cleaning them until they reach that percentage. You can not just pour in some injector "cleaner" as that only is alcohol, and doesn't really do much of anything... if at all.
You can get injectors semi-cleaned, but that's mostly just fuel system upkeep where they pour in different cleansers through the system. This is not an injector cleaning!
Injectors are sealed units and as such can only be cleaned certain ways as already mentioned.
Old 09-15-2008, 02:23 PM   #21
maui_boi
FC Rotary Power
well then i semi cleaned it then i took them out and dipped em and checked for flow and now we just going c if they click which we neva try yet..wat else could be the problem though??
Old 09-15-2008, 02:34 PM   #22
Dipping them does nothing but remove deposits from the outside of the injectors (and even then it's poor at that). Check the flow and get back to us.
There's no sense in moving forward to another cause until you know that the most likely cause is not it.
Old 09-16-2008, 01:26 AM   #23
maui_boi
FC Rotary Power
it doesn't spray when we jumped them with 12 volts well we couldn't see any sprays...
Old 09-16-2008, 01:28 AM   #24
maui_boi
FC Rotary Power
wat do u think could there be a problem with the plugs?
Old 09-16-2008, 01:47 AM   #25
send them to KGparts
http://www.injector-rehab.com/
Love the home page!!!!
Old 10-13-2008, 05:29 PM   #26
maui_boi
FC Rotary Power
sorrie i havent been on for the longest time but my car starts and runs good now just gotta clean the injectors still yet though cause i can feel it pulling back a little at full throttle but other than that all i did was change the TPS with another cars one and it ran fine after that so im guessing it was a bad TPS
