Show your rotary car build up. Show off your Rotary Car build! |
my new twins
Turbo 8
lookin' good!
Rotorhead
Cool setup. What are the specs on the turbos?
Other than ease of fabrication, what are your thoughts behind running a turbo off of each rotor rather than doing an X-pipe type of merge and then going with equal length runners to each turbo? How is the spool with this type of set up? Have you had it dyno'd yet?
![]() ||| Never argue with idiots. They will bring you down to their level and beat you with experience. ||| |
Different but interesting. What are the advantages over a stock set-up other than the turbo capabilities?
crash auto?fix auto
Loves it.
Rep Power: 10 ![]() |
I really want to see some dyno numbers and torque curves. I thought about something like this for the FD but found that the torque seems to come on about as fast as a properly sized single. That was the case with Howard Colemans setup and the twin GT28 setup that Jason did @ RX7 store.
what are the specs on these turbo's if you don't mind me asking?
50 trim Garrett To4E(s) mated to a .63 T3 with a stageV turbine wheel. Oil cooled only with a 360 thrust bearing upgrade. Turbine housings have been modified for 3" vband.
Twin 3" 304SS vband downpipes merging to a 4" midpipe Hard lined oil feed and return lines Twin Tial 38mm wastegates venting to atmosphere with -AN SS braided Teflon lines 100cc pre compressor 50/50 water alcohol injection, and 600cc post front mount Tial 50mm BOV Turblown lower intake manifold Heatshield |
#9 |
The car is still under construction and i will be posting dyno results, expected dyno is within the next 2 weeks or so. thanks for the compliments guys.
#10 |
Rep Power: 10 ![]() ![]() |
Can't wait to see some numbers!
#11 |
#12 |
okay guys driving with the twins is pretty amazing. still not tuned properly but boost comes on at 1700 rpms and climbs really fast.
#13 |
Dyno sheets man! I wanna see becuase this is something that I was thinking about doing for my FD
#14 |
93 red fd
#15 |
Any finished pictures/video?
Bookmarks |
Tags |
turblown twin to4 |
