| Old School Rotary (Pre-1979) Pre-1979 Discussion including performance modifications and technical support sections |
#11 |
Rep Power: 17 ![]() |
Hey guys, today I moved the wastegate outlet which fouled on my new radiator
.Cut it off and shortened it........ ![]() Then welded it up! ![]() ![]() The pipe from the barrel cooler to throttle body now welded. ![]() I made a mount for the coils. I think they should work there .![]() Here's a pic of the dump pipe, just tacked up at the moment. When I get the lower flange cut and tacked I can see if the flange will fit past the engine and steering box . Then I can weld that up as well.
RX4 coupe 20B conversion http://www.rotarycarclub.com/rotary_...ead.php?t=9884 |
| Tags |
| 20b, mazda rx-4 |
