Old 03-29-2011, 01:41 PM   #17
MmSadda
BOOSTED COLON
MmSadda's Avatar
MmSadda is on a distinguished road
Originally Posted by FRED View Post
On the right hand side of the engine bay find the pressure sensor attached to the front side of the right front strut tower area. The elect plug is yellow in color and has two sockets. It is not attached to anything. Get a piece of elect wire bare at each end. Put one end in each socket of the plug. Key to ON. Listen for the fuel pump noise running all the time.
This yellow fuel pump check connector might have black heat shrink around it. Possibly.
If the pump runs you Know the ENGINE fuse in the interior fuse box is good (third row up from the bottom and second fuse over on that row counting from the left as you look into the box. 15amp fuse).
This is when I'm facing the engine bay from the front of the car? It's on the right?
I see a little box labeled "pressure sensor" on the left, as well as another wiring harness. On the right, I just see the main fuse box.
Usually the tach needle will make one bump if you just turn the key ON. Normal. But it sounds like you have no tach action after that when you spin the engine with the starter. Odd.
Nope, no tach action after that.
MmSadda is offline
