Old 07-02-2011, 11:05 AM   #8
Here is the specs on the turbo...Thoughts?
Compressor: 76mm wheel w/ 50 A/R housing
Center section: Garrett oil cooled only
Turbine: 1.15 A/R divided to4e
You talking about this one?
Whoever is giving you the "specs" of the turbo is an idiot.
I need at least inducer and exducer diameters of the compressor wheel.
The compressor housing A/R is basically useless.
(For turbine side, the turbine A/R and turbine wheel trim is minimum info.)
All the 3" (exducer diameter) compressor wheels I've seen range anything from a T04B S-trim (which is basically the same size as the stock Hitachi HT-18) all the way up to a 60-1 / 62-1.
So you're talking power potentials anywhere from 250hp all the way up to 400hp.
See what I mean by useless?
