Old 12-06-2011, 06:49 PM   #18
Originally Posted by mattallac View Post
the aem coils are a little large but doable for my space situation the haltec ls1 coils are a little smaller
Don't waste your time with the LS1 coils, they are miserable little failures.
Originally Posted by C. Ludwig View Post
Skip all variants of the LS1 coil all together. Their output is far from impressive. The only LSx coil I would recommend is the truck coil (the one with the heat sink).
I BELIEVE that's the one with the auto-discharge, so setting it up properly in the ecu is key.... just ask the legions of RX8 owners that blew their engines while cranking it with the BHR upgrade.
You will never ever get ANY inductive ignition that will not drop output as a function of rpm *fact*
You will never ever get any inductive ignition that will run a true race spark plug of the coldest heat range from cold start *fact*
You will never ever get any inductive ignition that will fire 50% excess fuel as required in a turbo car, let alone any type of water injection system *fact*
CDI DO NOT create "electrical noise" unless it is a very poor install or fitted by someone who has no idea of CDI systems
But there are times when a CDI is just not needed. Hell, I picked up a whopping 3rwhp when I added a $1200 M&W box. Is that REALLY worth it? NO
rice racing my question is the second jen turbo came with inductive coils why didnt they use a cdi ,i do understand electrical theory and yes a cdi can magnify spark or a msd 6a box will multi spark (only to 3k) .i have ran my old repu on the dyno for testing with and without 6a boxes and there was no hp difference .that was a streetport 13b ,holly 600 ,road race header with dual 2" ,166hp to rear wheels at 7500 rpm.now as for turbo application on a rotary i have not tried a cdi yet. with the stock coils on my rx2 i am at 347 hpp on a mustang dyno at 10 psi.7500 rpm.aem coil is 118 mj ,up to 3.2ms
That's becuase MSD's suck.... it's short for My Spark Died. Your car is probably at such a low BHP rating that a CDI ignition system wouldn't make a difference. It's like putting a triple carbon disc on a stock n/a car.
