#1441 |
Rep Power: 15 ![]() |
#1442 | |
#1443 | ||
Rep Power: 10 ![]() |
![]() Quote:
It is sooooo much funBigger turbo... may not fit.... BIG EFR turbo...
#1444 |
IIRC he has the smaller EFR.
#1445 |
He does, but the ERF's are still physically bigger than most Garretts.
#1446 |
We have a problem..... be a man and get rid of that turbo drain HOSE and make it a hardline. Come on, if you are gonna do it, you might as well do it right. I should not have to tell you these things
![]() I like the tubing clamp. What is your source for them? Also, regarding your discolored wastegate... were they always water cooled or did you add that at a later date? Mine have like 6k mi. and a track day and are not discolored like that at all. For Diff and trans temp sensor I used the simple AEM temp sensor http://www.lms-efi.com/sunshop/index...t_detail&p=146 Last edited by RENESISFD; 02-07-2014 at 06:52 AM. |
#1447 | |
#1448 |
There is IIRC 5 refrence points. so I did the calibration using a spread of temps I think the temp sensor would see. (EX. 30 degrees to 250 degrees F) to get the best resolution at the temps I would normally see. It may not be perfect but IMO it is close enough.
#1449 | ||||
I thought about it... but in the end decided against it for a number of reasons. 1 being I can't get the turbo separated from the mani while in the car. So I need to pull them as a unit and it BARELY fits. Plus it's easier to work with. I did order the correct color fitting and some heat sleeving though ![]() Cheers. I get them through Verocious and Summit and Goodridge. Mainly through Verocious though.... I ordered a bunch for my boost lines to the WG. Swappinga few fittings on the WG's then first order of business when I get back is the WG lines themselves.... soooo I Should probably order my valves from MSC today.... Quote:
#1450 | |||||||
Rep Power: 20 ![]() |
Ok I'll check them out. Thanks! Quote:
I have the 7670. I'm not sure how it compares in size to a Garrett. I just know that with how short my runners are, and since I have my LIM spaced out about 1/8" due to the fuel rails pressing against each other, it really cramps the space. At least I don't have the wastegate actuator on mine so that saves some room. It should be somewhat comparable to a Garrett I believe. Depending on how much it would cost, I'd think about just paying you guys to build one and see how it fits when I get it lol. I also thought about trying to pick up a cheap, used HKS cast manifold to see how it would fit. Quote:
Yeah I have the MV-S wastegates in black and mine have never discolored like that. Mine has been all street driving though. Either way, I still want to run coolant to them with hard lines lol. |
#1451 | |||||
Those electronic bypass valves, the y-type that you plumb in with the exaust to go from full loud to full muffled.... I would like to run one on the 'vert but the sizes are just all wrong... so that will be the quiet car.... well..... as quiet as it can be with a 4" downpipe
![]() Quote:
![]() Quote:
#1452 |
Or the DC area, someone will be able to give you a ride.
#1453 | ||||
#1454 | ||
That... but I may need someone up in the CT area
![]() These guys.... http://quicktimeperformance.com/QTEC/ THe muscle car guys usually use them but it could be used for a recirc as well.... they're just not made small enough... oh well... the 'vert will be quiet. Quote:
Dude... Colin used them for his vac lines!
#1455 |
Hey you know I head down a few days earlier. It doesn't matter what I drive. I has spares in every state I live in!
