Get off my lawn!!!
Rep Power: 15 ![]() |
De-ABSing the FD
Ok, so I'm getting rid of my ABS during the current chapter of my rebuild (which reminds me a little bit of the old movie Groundhog Day
).I've already stripped out the ABS Module and am kind of playing it by ear on where I want to go from here regarding whether I want to retain the stock lines, proportioning valve, and MC. I'm using my (non-ABS) '93 Miata for comparison as I really don't have much experience with brake hydraulics. The FD has 5 brake lines with the ABS unit installed, 2x feed lines from the MC to the ABS module, and 3x lines running to the front and rear brakes. The proportioning valve mounted on the ABS module has a single input, and 3 outputs. My thoughts are that I could just "y" the two feed lines together and run them to the input for the prop valve and then connect the Right Front, Left Front, and Rear lines then be done with it. I just want to be sure that's a good idea though, and it's not going to have some unforeseen fuck-up later on that may cause an accident... My other concern is whether or not the stock MC is going to work well enough with the removal of the ABS module considering I've got bigger brakes up front (Wilwood BBK) and in the rear (Racebrake oversized kit). If I'm going to need/want to upgrade or otherwise change out the brake MC now would be the time to do it... I'd love some input from people smarter than me about this ![]() Cheers, Levi
'94 Touring - Cursed '96 NA Miata '14 Mazda3 Hatch '14 Aprilia RSV4 R |
Rotary FTW!
Would you consider selling the front right ABS sensor?
'94 RX-7 Touring Street port, BNR twins, Power FC, ID2000s w/ FFE rail, RB cat-back, DP, MP, Apexi FMIC, Aeromotive FP, Profec B Spec II, Sakebomb wires, ACT s/s clutch |
Get off my lawn!!!
At this point I'd rather keep it all in place, and I say this for a few reasons:
1) Extra effort to remove it, when it won't hurt to let it remain. 2) My ECU is capable of running Traction Control, and in the future I may decide to activate that option. The ABS sensors could well double as sensors for the TC, so I'd best keep them in place. 3) I have no idea what it is/would be worth, and I don't want to A) insult you with a retardly high price, or B) sell myself short by selling it for stupid cheap. I'll let you know if I change my mind though!
Rep Power: 20 ![]() |
I just deleted my ABS also, and kept the stock proportioning valve because I'm about to switch to RZ brakes (aka, a larger, thicker, stock brake system).
First of all, DAMMIT! I removed all my ABS sensors from the wheels, and I remember reading the Adaptronic can do a form of traction control, but I'm not sure if it would use those sensors as a reading so it may be alright lol. I had gotten a delete kit from Alex Rodriguez, but a local guy did his with seamless copper line from Advance Auto parts and used the stock proportioning valve (and since I'm sticking with a form of stock brakes, I wanted to do mine like that too instead of an aftermarket valve), so I copied his setup. Well, almost. Mine is a little different. Like him, I made a mount to mount the valve directly under the master cylinder, but I mounted mine at a different angle. Here are some pics... Here is the mount... ![]() ![]() And here are some pics of how it's mounted. I remade some of these lines and replaced some fittings already because I had a problem with it leaking, but I think it's good now. ![]() ![]() ![]() I ran the line to the passenger front under the crush rail so you can't see it. ![]() ![]() I rebent the front lines coming into the bay from the wheel wells so they could meet up with the lines I made. ![]() The lines that I remade look better because I used a tubing bender and got the bends a lot tighter and cleaner, but I don't have any pics of it now. I can take some if you want. |
#5 | |
#6 | ||
Professional Stick Poker
http://fedhillusa.com/ The flaring tools they sell/rent are top notch and the tubing beats the hell out of automotive store tubing.
#7 | |||
That's good to know. Thanks! Quote:
#8 | |
Get off my lawn!!!
#9 |
Get off my lawn!!!
Looks really nice man!! What did you do about the single input for the prop valve wrt the two lines pushing from the MC?
#10 |
Are you talking about splitting the line to go to both front brakes? If so, you should be able to see in pics 3 and 5 the tee fitting I used. I think you can find a M8x1.0 tee fitting (I'm pretty sure that's the stock fitting thread), but I used 3/8" and did only those three fittings in 3/8", the rest are metric. I got everything at Advance Auto Parts, except the bender tool I got from Autozone IIRC. Whatever tee fitting you get, just make sure they cut the threads deep enough so you can tighten the fitting down far enough for it to not leak. I believe that's what the problem was with the first tee fitting I had. The middle line would not stop leaking. I remade that line four times until I thought about it lol.
Oh and another thing, I ABHOR using the flaring tools you can get from any parts store or Harbor Freight. I'm still not sure if it was just bad tee fitting and couplers or if it was the shitty flare the tool made, but I was seriously thinking about getting the Eastwood tool. I was going to if it still leaked. Last edited by speedjunkie; 08-25-2014 at 06:27 PM. |
#11 |
Get off my lawn!!!
I was referring more to where you plumbed in the two lines leading from the Master Cylinder. I was trying to figure out what goes where in the proportioning valve, I think I've got it now though...
Heres the Prop Valve: ![]() Essentially the two ports on the left are the "in" ports from the MC, and the two ports are the out ports leading to the brakes. The upper one leads to the front brakes, and the lower one leads to the rear, correct? Yeah, I had run out to one of the chain autoparts stores (I can't remember if it was Advanced or Autozone) and picked up a bunch of their cheap pipe tools. After consulting with BAW I returned them, as it was a waste and I'd end up binning them all anyway I'm just gunna borrow quality tools from Mike
#12 |
Yep, that's it. The way we have it plumbed is the outlet of the master cylinder that's closest to the brake booster (directly under the reservoir) goes to the front brakes and the one at the end of the master cylinder goes to the rear brakes. I just copied the other guy's setup, I haven't actually used it yet but it seems to work on his car lol. I'll take a pic and post it.
#13 |
Get off my lawn!!!
Ah, right on
#14 |
Ok, I'm an idiot lol. Last night I had it typed out correctly and then changed it thinking I had it wrong. Turns out I was right the first time. The port directly under the reservoir goes to the rear brakes, and the port at the end of the master cylinder goes to the front brakes. Here are pics of the current setup. I finally got them to stop seeping but I'm still paranoid lol, thus the towels. The whole system is pressurized and the brakes are bled, but I'm paranoid because the engine bay has fresh paint also. The bender tool dinked the lines a little but it made the bends much tighter and cleaner looking. I ran the line for the front brakes between the master cylinder and the reservoir just because it seemed like the most direct route.
#15 | |
