Rotary Tech - General Rotary Engine related tech section.. Tech section for general Rotary Engine... This includes, building 12As, 13Bs, 20Bs, Renesis, etc... |
So you can try a little experiment to test this hypothesis. Install a .0015” feeler gauge at the center of the apex seal simulating the raised spark plug area. The seal will be rocked-over .003“ and the wedge will put pressure on the pointed end of the apex seal. Note the exaggerated condition depicted at the top of the picture.
![]() But we still haven’t gotten to the root cause. The real problem is the raised spark plug area on the housing. There are at least three approaches to this problem: (1)- Use cold heat range plugs like NGK R7420-10 or 10.5. (This is easiest part of the solution.) (2)-The harder second part is to cool the housing better. A better pump is a good start. Second gen. cast impeller type pumps are a lot better or the Remedy pump for 3rd gens. (3)-The most difficult part would be to port the housing in the spark plug area to minimize distortion. But what is the best way? The factory racing peripheral housing have a trough cast into the inner water jacket in this area but the are for NA applications. ![]() Notice that the thru-bolt bosses have been severed. |
Bookmarks |
Thread Tools | |
Display Modes | |
