Old 03-31-2008, 02:22 PM   #1
classicauto
crash auto?fix auto
classicauto's Avatar
Originally Posted by Max777 View Post
I cant quite get to the block drain plug to drain the rest of the coolant out... I think I will need to take out the AC compressor to make the job easier.
Look at your drivers side engine mount where it bolts to the block. Notice the 3 studs/nuts? Notice the long hex "nut"? Undo the hex nut and you'll drain the coolant out of the block. IIRC that drain is lower then the one behind the P/S pump bracket anyways.
My radiator had quite a bit of CRAP logged in there. I sprayed a TON of degreaser, follwed by garden hose, an then power washer. The radiator is pretty much see through right now.
Nice, thats always good
