Old 11-11-2010, 03:15 AM   #1
dr50376272
dr50376272 is on a distinguished road
fuel pump
my engine wont start. i wonder, i hear no sound from the fuel pump. do you think there should always be a sound from the oil pump? im 100% sure in all my other rotaries there was a sound. its an rx4 auto 12a twin dizzy coupe, pump is original. please do reply either here or dr50376272@gmail.com
thanks
david
dr50376272 is offline   Reply With Quote
Old 11-11-2010, 07:46 PM   #2
rxspeed7
The fan hit the shit!
rxspeed7's Avatar
rxspeed7 is on a distinguished road
Wait so your fuel pump doesn't turn on? Or your oil pump quit? If its the fuel pump, first check all wiring and fuses, if all that checks out fine then your pump probably failed.
Zack.
87 TII= High comp 13b-re,S360,Link G4 RX
I suppose you could orally BDC or even anally BDC someone? or be BDC'd in those two ways also
Many ways you can get BDC'd
rxspeed7 is offline   Reply With Quote
Old 11-12-2010, 09:12 AM   #3
My5ABaby
My5ABaby's Avatar
It seems this isn't a 2nd gen, but in mine I can't hear the pump unless the car is off and I jumper it to run. Stock pumps are pretty quiet.
Community Service Manual
RotorWiki
Old 11-12-2010, 12:31 PM   #4
sen2two
KTEC
sen2two's Avatar
thanks
david
Oil pump or fuel pump?
Like it was already stated, stock fuel pumps can be very quiet. Especially if you have an in tank pump and the tank is full. I think Rx4's had an external pump though.
Either way, if you want to do it by ear, crawl undermeath the car and listen for the pump. Or pull a fuel line and place it into a container so it will not spill. Turn the key on and see if fuel flows out.
what I have:
What I had:
Old 11-12-2010, 09:41 PM   #5
dr50376272
i have a stupid dumb question. if there no fuel in my fuel tank, will the fuel pump run? mine coughs and splatters when there is no fuel in the tank, but when i took it out and ran a 12v source through it, it continually ran. also, rx4 mazda, where is the fuel tank fuse? thanks !
