Old 12-17-2010, 12:47 AM   #1
NoDOHC
NoDOHC's Avatar
The spark plug hole has to go on the compression side of the housing.
Take a second look at that housing in the picture, you will see that I mean. the one on the right is a spark plug addition, on the left, P-port
If you move the P-port up that high, you will be missing any advantage that the P-port would give.
Methanol would be cooling the intake charge if injected there, which is what you want.
Out of curiousity, why do you always remove stock OMP?
