Old 01-20-2011, 09:24 PM   #1
FC Zach
FC Zach's Avatar
Originally Posted by IH8DSM View Post
So i'm trying to install this aluminum flywheel on my car, trying being the keyword. I've got the rear counter weight on there correctly and the clutch fits but when i go to put the pressure plate on its got almost a half inch gap between the flywheel and the pressure plate. The flywheel is completely flat with no dowels in it, the clutch is recessed into the flywheels so its the pressure plate that is making it raised.
So heres my question do i need to use a aftermarket pressure plate, spacers and longer bolts or what? I've never installed a light weight flywheel on a rotary before and from everything I saw I thought it just bolted up and was good to go. I have no idea what kind of flywheel it is either.
Any help at this point would be appreciated
The prressuer plate should work on the flywheel if it is designed for the RX but if it's unknown of the flywheel compatibility to the RX then I'ld say your shootin in the dark.
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 01-20-2011, 09:31 PM   #2
FC Zach
FC Zach's Avatar
The outermost portion of the clutch disc should be facing the pressure plate and it should also be mentioned that if there is a gap after tightening the pressure plate bolts
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
