cxxxx|::::::::::::>
Bought from dudemaaan on this forum.
![]() RE hood struts ![]() Ended up changing the fuel system around. I was told hooking the feed up to the secondary rail was better so that's the way i went. If you have any suggestions let me know. Pump mounted ![]() Meth line i wrapped it since braided lines have a tendency to eat through things ![]() So i first tried to put the novel in the black coupler i had only problem is it's to thick and i couldn't thread on the backing to seal the coupler ![]() So i had to use an old blue coupler i had that's a bit smaller i'm sure it will work right but i need to find something else. You can see the silver washer looking thing on the blue i couldn't get that piece on the black coupler ![]() Fixed ![]() Pressure light Red when building Green when on ![]() Low level light ![]() Fuse block for pump ![]() ![]() ![]() Main power and main ground just left to run and a retune yaaa Last edited by Force13b; 02-10-2011 at 03:42 PM. |
