#8 | |
Update:
On the subject of the Remflex gaskets, here are my results: I installed two of these in my RB dual-tip CB (one between the stock cat and the CB, and one in the CB middle joint). The Remflex instructions say to compress the gaskets ~50%, from the initial 1/8" to 1/16" thick. This took ~40 ft-lb of torque on each of the 4 bolts involved (2 stock rear cat nuts, and 2 7/16" RB mid-flange bolts), even though the contact area was much less from the RB flange to the cat flange. After driving ~35 miles,with several full-throttle power applications, I rechecked the gaskets and bolt torques. The gaskets seemed perfect, with absolutely no sign of leakage or distress. The bolts had loosened a few ft-lb, so I re-torqued them (despite the Remflex claim that re-torquing is not necessary) to the 40 ft-lb and used wicking Loctite on the nuts. So far, so good.
Dave '93 Base VR bought new in March 1992, PFS SMIC & CAI (modified), HKS DP w/ Jet-Hot 2000, RB dual-tip CB, Linearized OE temperature gauge, Dual "Home-Depot" ceramic ball-spring MBC's, Pettit AST Last edited by DaveW; 04-04-2008 at 10:14 AM. Reason: Added more info |
