Old 05-06-2008, 12:21 AM   #1
Eatmyclutch
business as usual
Eatmyclutch's Avatar
Eatmyclutch is an unknown quantity at this point
Angry Why does my battery keep on dying?
Replaced old alt with a new one about a month ago.
Ever since, I've been through 3 new batteries and 2 charges...ideas plz?
Bitch
Eatmyclutch is offline   Reply With Quote
Old 05-06-2008, 04:29 AM   #2
Kentetsu
Kentetsu's Avatar
Have you confirmed that the new alternator is charging?
Old 05-06-2008, 09:42 AM   #3
TehMonkay
Yeah check your voltage while running.
Old 05-06-2008, 01:55 PM   #4
Eatmyclutch
business as usual
^^^ Voltage meter bounces from 10-12 volts.
I think this may be the problem. How can I fix the charging issue?
Bitch
Old 05-06-2008, 02:04 PM   #5
Viperx7
Viperx7's Avatar
Viperx7 is on a distinguished road
You may also have a ground problem. Mine was doing the same thing a few years back. I got some wires with alligator clips on them and attached one between the engine and body. Voltage went right up. Switched it with a battery cable with double ring terminals and haven't had a problem since.
Mike Chrisman
83 Rx7 Turbo
85 Rx7 GS
89 Rx7 GTU
http://www.cardomain.com/ride/409797
"Don't apoligize for being Patriotic, F**k 'em. TK"
Viperx7 is offline   Reply With Quote
Old 05-06-2008, 02:22 PM   #6
Eatmyclutch
business as usual
Well, used a volt meter batter messured out to be 12+ volts, but the alt was at 11.78...
Maybe I installed the alt incorrectly, but everything seems to be plugged in properly.
Bitch
Old 05-07-2008, 09:59 AM   #7
Kentetsu
Kentetsu's Avatar
On the "T" plug that goes into the back of the alternator, the vertical part of the T should be showing 12 volts while the ignition is on. This sends the signal to the alternator, letting it know the current voltage of the system so it knows when to start charging. If you don't have 12 volts showing at that part of the plug, then the alt will not enter charge mode.
If it shows no voltage, then check the fuses under the dash.
Old 05-07-2008, 09:30 PM   #8
Eatmyclutch
business as usual
Turned out to be the alternator. Hopefully my replacement will do better justice. Thanx for the helpful responses.
Bitch
