| 1st Gen RX-7 Cars For Sale Buy or Sell your Car only!! No Parts! |
Talk - Action = Nothing
This was taken from one of the build thread post:
"The shell was completely stripped of all parts. Shell was then prepped by aircraft stripping all the wheel wells, interior and engine compartment. Once clean we began to repair the wheel well rot. Sections were cut out and new sheet welded in place. We used new upper arm support brackets removed from a donor chassis to complete the repair. All non used holes were filled on the firewall with round slugs cut from sheet metal and welded in place. Once the welds were ground down you can not see where the hole were. Threaded bungs were welded in place for the hood pins and the fuel pressure regulator bracket was fabricated and welded to the pinch weld on the firewall. Brackets were fabricated and welded for the second generation oil cooler mounted in front of the radiator. We then covered the tire well with our normal fuel cell block off panel though we have chosen to stay with the stock tank for a while. A simple 4 point bar was fabricated from 1.5" x .095 wall DOM. The bar was built to help support the rear shock area for possible future updates in the back. It was also built so that it can be updated to a full cage later. Once chassis fabrication was completed we sprayed the engine area, interior and wheel wells gloss white. Our goal with the car is a streetable, track day car that represents our abilities and product line. We wanted to build the vehichle with an "old school" look. It will be used for a few track days her an there as well as to show the vehicle at events like Deals Gap and SevenStock. To attain this goal we decided there would be interior from the main hoop forward. There would be a full street legal wire harness. All the parts for the vehicle would come from our online store or our available sources just as our customers would do." The following list is what was used and done during the build: Drivetrain: FB gearbox Mazda Trix New drive shaft with replaceable u-joints GSL-SE pumpkin ReSpeed HD Axle retainer plates Exhaust: PROTOTYPE ReSpeed Pre-Silencer Borla SS Muffler ReSpeed fabricated mandrel exhaust. 3" to 2.5" over the axle housing. Brakes: ReSpeed Mark I front and rear big brake kit. Brembo blank rotors, re-drilled 4 lug EBC Green Pads ReSpeed re-manufactured caliper sets ReSpeed Stainless line kit Rear brake bias lever with stainless plumbing Front Suspension: ReSpeed Race coil over kit ReSpeed 350# front springs Modified and powder coated front spindles ReSpeed Caster/Camber Plates ReSpeed Spherical kits Tokico 5 way inserts (Race) ReSpeed 1" Roll center blocks ReSpeed Tubular Competition Sway Bar ReSpeed Strut Tower and Firewall Brace Rear Suspension: ReSpeed rear spring adjuster kit ReSpeed 175# springs ReSpeed Tubular Rear Lower Control Arms Steering: ReSpeed rack/pinion kit with Aluminum engine mount upgrade Flaming river 15:1 rack Ignition: MSD 6A on leading, direct fire ReSpeed 3 Coil Mount Autometer Rev Limiter Electrical: Two completely independent wiring systems. First one is a painless fuse box kit that handles all ignition, fuel and electric fan circuits. Fuses are mounted to the dash for quick repair. Second is a gutted stock harness that handles the street car aspects like turn signals and wipers. The stock harness was laid out and unwrapped, all unwanted wires were removed. Pop up headlight motors were removed. ReSpeed FC fuse box bracket. Relocated battery with fabricated mount structure ReSpeed Quick headlight pop up stays Fuel System: Holly adjustable regulator ReSpeed 0-10 Fuel Pressure Gauge ReSpeed Dry Break General: Relocated oil filter using ReSpeed block off and filter mount -10 Stainless oil cooler lines Second generation oil cooler ReSpeed Cold air radiator support Wheels: 15"x8" SportMax wheels - Zero Offest Tires are 205-50-15 with maybe 500 miles on them |
