crash auto?fix auto
The FCD's install won't effect the wiring for the tach or coils in any way.
I'd be looking at the CAS wiring and the gears and teeth inside it. Then I'd be checking the coil packs. Your tach drop symptoms sound similar to an issue I had with cracekd insualtion on the CAS wires where they the CAS body through the rubber grommet. |
Bookmarks |
