Rep Power: 20 ![]() |
Turbo, RTV, Block off plates, and advice...
So I'm having trouble with my car just a month or so before I plan on putting on all the stuff for the turbo. My car now on occasion feels like there's a massive vacuum leak. The trouble is it's intermittent. I recently replaced my EGR valve with a blockoff plate and while I was attempting to remove the gasket from the EGR valve it disintegrated. I used RTV on it and made a pretty good seal. I took it out for a test drive and I noticed that after it warmed up it started behaving like it there was an air leak. I then took it all apart and re-applied RTV more liberally and that seemed to correct my issue.
I then had to park the car for two weeks for a trip out of state. I came back and I started to have these problems again. The temperature has been getting extremely low (down to the single digits) and that's when the problems seem to have started. I'm curious as to whether or not the RTV is unable to seal properly like it used to and so I should order an EGR valve gasket and re-do it, or if my engine is on the fritz and is in need of a rebuild? I'm going to do a compression test on it tomorrow to see what the numbers are. The last time I did one however my numbers were excellent 115/115 and hit 30/30/30 on each face and that was maybe, MAYBE 8 months ago. Now more to the point since I am planning on putting the turbo on within the next few months should I rebuild the engine anyways? Just build and port it when I put the turbo on while I prep the engine bay? How much do soft seal rebuild kits go for (as I think that my apex seals are fine)?
crash auto?fix auto
The RTV should seal fine if its applied properly and the surfaces aren't warped.
Hard to say what that issue is... As far as rebuilding before strapping the turbo on - ABSOLUTELY. And unless your engine has been rebuilt fairly recently, you'll probably need more items then a soft seal kit as there will likely be 3 piece apex seals in it. Make sure to spec out all the hard parts....but a coolant o-ring, plus all dowel oring kits from mazdatrix are only a couple hundred dollars. But oil control rings/seals, all springs etc should be measured and replaced if necessary. But in my experience, unless its been fairly recently built or freshened - you'll be in for more then you think. |
#3 | ||
It's having trouble turning on now. It's too cold so I can't really get my plugs out so I can't do a compression test or see the condition of the plugs. It's tending to flood more than not, and runs strong more than not when it actually does manage to turn on. There are instances when it does not run strong and is in need of some fancy driving to keep it from stalling out, but more so than not it runs fine.
What is the problem? Is it the plugs themselves? The temperature? A combination of old plugs, temperature, and flooding? Could my previous symptoms be another aspect of this problem or is it an indication of another problem that I'll need to fix? Guesses?
Maybe you should adjust the RTek. Temps have been drastically colder in VA the last few weeks.
Also, put new plugs in. I cant stress the value of spark plugs in a rotary, lol... |
#6 | ||
The plugs themselves are probably approaching 25-30,000 miles on them, which would be about the time for a replacement or at least a very thorough cleaning. Hmmm.... I may even be able to run a compression check when I get up to culpeper. That should be quite revealing.
You doing the turbo install in culpeper? Which weekend....
As for plugs, if you did any tuning on those plugs when you got the RTek, they'll probably need cleaning/replaced... i remember tuning a T2 a while back and after hours of work, it never wanted to start... put new plugs in, and it fired right up. Its usually simple. I would def do the compression check too though. Even if its been rebuilt, who knows the quality of the rebuild.... |
#8 | ||
Nah, I'm going to be doing the turbo install down in Christiansburg as I'd have access to a lift, tools, and a slew of master welders (or at least certified or self taught welders that have a tig).
#9 |
I'll be doing a compression check tomorrow and looking at the plugs.
On the way up it ran like complete crap (RTek registered lean, though I was definatly spewing fuel in the exhaust pipe and doing back fires and flames). Will look at the condition of the plugs and report back come morning. Hopefully it won't be so F'ing cold this time.
#10 |
Okay, so I checked compression on both rotors. I'm getting around 50-60psi on each face and a total compression of 100+psi (using piston compression tester) both front and rear.
I pulled the plugs and they're a little fouled. One of the leading plugs isn't looking too good as the piece in the middle has been warn away compared to the other one (not as pointy). When I pulled them however I noticed the first had alot of oil and and seemed well lubricated (front). When I pulled the second (rear) I noticed it had alot of oil and fuel mixture in it. I don't know why it's flooding on the rear when compression is so high. Any thoughts on why a very good compression engine is flooding out? (As a side note, I'm only able to secure trailing plugs right now. Would putting those in the leading position affect anything?)
The Official FC Radiator Thread My Project Thread: Cerberus CCVT Virginia Rotary Group Last edited by vex; 01-24-2009 at 12:16 PM. |
#11 |
So I got a full set of plugs (at least I ordered a full set; both leading and trailing). Ended up only getting 4 leading. No biggie. I look at the gapping for the new plugs and I realise why my engine's been running so crappy lately. My spark plugs are definatly shot more than a dead zombie corpse on a marine base.
The elctrodes on the old plugs have been melted/warn away to almost just little blobs/spikes. Couple that with the amount of carbon on them and I think I know why the plugs only worked the way they did. I'm very surprised by how well the car ran. I'll replace the plugs tomorrow to see if that remedy's my problem. On a side note will running a full set of Leading plugs pose much of a problem? I'm planning on putting the car in the garage and putting on a turbo in the next week (it'll be down for a month or so). I'm of the thought that it won't be a problem since the plugs themselves are a cooler plug and will take to the additional air and heat without much of a problem.
#12 |
Rep Power: 22 ![]() |
I run leading plugs all around. I have ever since I did the turbo swap with no emissions.
No ill effects. It actually runs a whole lot better that way.
#13 | |
I won't know too much more about the current state of affairs until after I start driving it around more. At least I feel like it'll be able to get me to the garage without problem.
#14 | ||
crash auto?fix auto
I've run all 7's in some of my N/A DD's before.....never been a problem. Quote:
#15 |
Thanks for the clarification about the plugs.
I'm still having trouble with the engine dying after a little while. I'm going to try to hunt down a vac leak (if there is one) and see if that solves my problem. If that doesn't work I'll just tear into the intake again and remove the EGR Block off plate and clean up the mounting one last time and install it. I may go out and purchase a gasket maker compound or something instead of the RTV red.
| Tags |
| coolant seal failure, egr block off, rtv, vacuum leak |
