hammer didnt work. Its also a 5speed swap using this for wiring: Step 5: Reverse Lights and Neutral Safety Switch
Locate the two red wires on the manual transmission, keep them in mind. Look for a white three pronged clip that used to plug into the automatic transmission, cut all three wires and connect the bottom two together "this will allow you to start the vehicle" and connect the top of the three to one of the red wires on the manual transmission "doesnt matter which one, you will need to add some wire to complete the connection". Now take the other red wire and run it into the inside of the vehicle through the shifter hole " you will need to add soem wire to complete the connection" locate the wiring harness in the shifter area that used to connect to the automatic shifter assembly. Locate the 4 pin clip, now locate the black with yellow stripe wire and attach it to the wire you ran inside the car from the transmission "this will allow your revers lights to work". my warning lights dont come on either. Could it be the ecu?? any other suggestions?? |
