Old 10-03-2009, 05:38 PM   #1
Glass Machine
Glass Machine is on a distinguished road
Originally Posted by need RX7 View Post
From what I understand, they taper the end of one shaft, and insert it into a matching hole bored into the end of the other shaft, and use a key to connect them (like the front hub to e-shaft, etc). I imagine you could also spline them, but that would be harder to machine.
Thanks for the link some good stuff on there...
Now as for machining it don't matter how hard it would be. If it can be done and be done better then that's the way it will be done. With the power that this would be making (1000+ ) there is no need to make the E-shaft out of anything but the strongest mineral I can get my hands on even if it adds a bit of weight.
Glass Machine is offline   Reply With Quote
