| 3rd Gen RX-7 Engine Parts Only Engine Related parts ONLY! |
Hi, I would be really interested in several of your parts, i would like pictures of your UIM,LIM,TB,Alt,Apexi AVCR boost controller, complete fuel system,Banzai motor mounts and midpipes. would you combine shipping on multiple items and do you take Paypal? i'm in Atlanta,GA zip code 30043. How much power were you making on your setup? e-mail me at Gamma_rayburst@yahoo.com thanks.
UPDATE:
My paypal addy is: e_money@excite.com Prices are with shipping unless other wise said. Short block - $1800k app : 5k miles +SHIPPING Greddy front strut mount bar - $90 Pettit AST w/cap - $80 banzai Poly motor mounts with engine mounts - $200 SOLD 5 Speed Transmission w/newer 5 gear sync - $400+SHIPPING comes with short shifter. XTR 6 puck clutch - $225 lightweight flywheel - $100 Or $300 together Turbo Kit Garrett T60-1 turbo (4k miles on it) - $375 SOLD HKS 38mm wastegate (8k miles on it) - $275 PENDING HKS manifold (cast iron/8k miles on it) - $300 PENDING 3" Custom downpipe w/ 3" V-band and O2 bung - $175 SOLD Custom Single turbo engine harness - $200 PENDING Apexi AVR boost controler - $300 SOLD HKS twin ignitor - $325 SOLD E8 Haltech ECU with fling lead, WB 02 sensor and gauge - $1200 Or $900 for ECU $300 for sensor and gauge. LT8 Microtech with new wiring harness - $800 LS1 coils,8mm plugs wires, 3 bar map - $125 Polished parts: Alt - $75 SOLD UIM - $125, has block off plates for single turbo SOLD LIM - $100, has block off plates for single turbo Acces. bracket - $50 Water Pump - $75 TB - $75 w/block off plates SOLD CUSTOM FUEL SYSTEM: 1300 sec/850 pri (DENSO), SARD fuel regulator/AN lines and fittings,and stock rails - $400 SOLD Subframe - $75 Rare Blitz FMIC with piping - $1300 Greddy Type S BOV - $150 Greddy Elbow - $100 PENDING (polished everything) FOR EVERYTHING - $1400 Koyo rad (polished) w/Hoses - $300 Stock fans - $75 Rx7Store.com midpipe resonator - $225 HKS Ti CF can cat back - $300 Hi-Flow midpipe - $175 Driveshaft - $65 Solid Megan racing tie rod ends - $75 19" Stern (ADR) wheels and tires. P275/30ZR19 Kumho Escta SPT rears 5k miles on them P225/35ZR19 Conti Extreme DWS fronts 1k miles on them $800 + SHIPPING Everything is still in the vehicle and you can hear it run, up untill I start parting it out. If you want pics please let me know and I will try by best to get them to you with-in 24hrs. Last edited by rx7man1993; 08-16-2010 at 11:47 AM. |
UPDATE:
My paypal addy is: e_money@excite.com Prices are with shipping unless other wise said. Short block - $1800k app : 5k miles +SHIPPING Greddy front strut mount bar - $90 PENDING Pettit AST w/cap - $80 PENDING banzai Poly motor mounts with engine mounts - $200 SOLD 5 Speed Transmission w/newer 5 gear sync - $400+SHIPPING comes with short shifter. XTR 6 puck clutch - $225 lightweight flywheel - $100 Or $300 together Turbo Kit Garrett T60-1 turbo (4k miles on it) - $375 SOLD HKS 38mm wastegate (8k miles on it) - $275 PENDING HKS manifold (cast iron/8k miles on it) - $300 PENDING 3" Custom downpipe w/ 3" V-band and O2 bung - $175 SOLD Apexi AVR boost controler - $300 SOLD HKS twin ignitor - $325 SOLD E8 Haltech ECU with fling lead, WB 02 sensor and gauge - $1200 Or $900 for ECU $300 for sensor and gauge. LT8 Microtech with new wiring harness - $800 LS1 coils,8mm plugs wires, 3 bar map - $125 Polished parts: Alt - $75 SOLD UIM - $125, has block off plates for single turbo SOLD LIM - $100, has block off plates for single turbo SOLD Acces. bracket - $50 Water Pump - $75 TB - $75 w/block off plates SOLD CUSTOM FUEL SYSTEM: 1300 sec/850 pri (DENSO), SARD fuel regulator/AN lines and fittings,and stock rails - $400 SOLD Subframe - $75 Rare Blitz FMIC with piping - $1300 Greddy Type S BOV - $150 Greddy Elbow - $100 SOLD (polished everything) FOR EVERYTHING - $1400 Koyo rad (polished) w/Hoses - $300 Stock fans - $75 PENDING Rx7Store.com midpipe resonator - $225 HKS Ti CF can cat back - $300 Hi-Flow midpipe - $175 Driveshaft - $65 Solid Megan racing tie rod ends - $75 19" Stern (ADR) wheels and tires. P275/30ZR19 Kumho Escta SPT rears 5k miles on them P225/35ZR19 Conti Extreme DWS fronts 1k miles on them $800 + SHIPPING Everything is still in the vehicle and you can hear it run, up untill I start parting it out. If you want pics please let me know and I will try by best to get them to you with-in 24hrs. |
